Custom Tools (Form Tools)
This topic explains how to create custom milling or drilling tools (form tools) in BobCAM.
Custom Tool Geometry
The process of creating custom tools in BobCAM includes creating a wireframe profile of the tool that is revolved around the Y-axis of the selected coordinate system. You create solid entities to define the cutting portion of the tool and dashed entities to define the non-cutting portion of the tool. You then assign the geometry to the tool and define its parameters.
Note: You can create custom tools for any milling or drilling tool type as well as lathe drilling tools. The custom tools can then be used for any milling or drilling operations that support the tool category in which the tool is made.
There are a few key points to creating the geometry for custom tools:
Custom Chain
Custom Tool
Custom Chain
Custom Tool
Assigning Custom Tool Geometry
After defining the custom profile for a tool, you assign the geometry to the tool using the Create/Modify Tool dialog box that is accessed from the Tool Library.
  1. In the CAM Tree, right-click CAM Defaults (or Mill Tools), and click Tool Library.
Note: You cannot assign custom tool geometry when accessing the Tool Library from the CAM wizards.
  1. Select a tool category on the left, such as Endmill Rough, to filter the tools list.
To create a new tool, click the Add button.
To modify an existing tool, select the tool in the tools list, and click Modify.
  1. In the Create/Modify Tool dialog (titled by the selected tool category), click the Assign Tool Geometry button.
Note: After assigning custom tool geometry, the Assign Tool Geometry button changes to Remove Tool Geometry. You can use this button to remove the custom geometry and assign a new geometry profile.
In the graphics area, click to select all entities in the custom chain. If you are not using the WCS, you must also select a coordinate system. The software revolves the tool around the Y-axis of the selected coordinate system. When you don't select a coordinate system, the WCS (SolidWorks CAD origin) is utilized.
Important: When selecting sketch geometry, select the sketch entities directly from the graphics area. If you select a sketch from the Feature Manager design tree, the construction geometry is removed, which may provide incorrect results.
  1. Click to finish.
    When you confirm the selection, the software returns you to the Create/Modify Tool dialog box for you to finish defining the tool. A preview of the custom tool displays on the right side of the dialog box. The software automatically sets some tool parameters based on the selected profile, but you must confirm all parameters.
  2. Enter all tool parameters for the custom tool and click OK to finish.
Tool Data Parameters
The software automatically populates many of the tool parameters based on the custom geometry that you define, but there are two key points:
The software sets the tool parameters based on the custom tool chain you select as follows:
The Tool Library
