Depth of Cut - sets the spacing between toolpath passes.
Rough Allowance -
Selecting this option will create a pass before the final
pass to act as a semi-finish. The spacing of the semi-finish pass will
be dictated by the values entered in the Z and X boxes.
No Allowance |
Finish Allowance |
Rough & Finish |
No Allowance Simulation |
Finish Allowance Simulation |
Rough & Finish Simulation |
*Steps can also be eliminated with the Overlap options below. |
Overlap
The Overlap options allow you to create an additional move prior to the link to the next pass. This link will track back up the geometry in order to eliminate stair steps as seen in the images above. Overlap is controlled with either, To Previous Cut, No Overlap, or Custom Distance.
To Previous Cut - automatically
tracks back up the geometry the distance of the selected depth of cut.
No Overlap - does not track back
up the geometry at all.
Custom Distance - Allows you to
enter a custom distance value. This value is a vertical distance. Entering
the same value that has been entered for the depth of cut will track back
to the last cut exactly.
Corner Type
Round - keeps the specified tool
geometry in contact with the geometry at all times.
Sharp - allows the tool to move
off the geometry in order to line up with the next move on the following
entity. This method eliminates the rounding over of the tool.
Theoretical Point on Tool |
Rounded Corner |
Sharp Corner |
Bounds
Trim to Stock -
Selecting this option will trim away toolpath that extends beyond
the Operation Stock.
Trim to Stock off |
Trim to Stock on |
