Mill Tool Page
This topic serves to describe the various tool pages available going through Mill and Mill Turn jobs. It is good practice to have all the tools for the job loaded into the Tool Crib at the start of the job. If you do, the tools for the job will already be in the Tool Crib, and the system will have pulled appropriate tools for each operation from the Tool Crib. From this tool page, you can either, choose a different tool from the Tool Crib, go into the Tool Crib to add tools from your Tool Library, or enter tool specific data manually into the Tool Data Section of the page.
This page will also assist in assigning Tool Numbers and Offsets, and Coolant options, as well as Speeds and Feeds.
Tool Data
To select a tool for the feature,you can use the following option in one of two ways.
System Tool
Select this check
box to allow the software to automatically select tools from the Tool
Cribthat match the machining
operation. In the case of end mills, you may alter the diameter and corner
radius allowing the software to find the appropriate tool from the Tool
Crib. In the case the appropriate tool sizes are not found, the software
searches for a matching tool in the Tool Library. If a matching tool is
found, it is added to the Tool Crib. If a matching tool is not found,
a new tool is automatically created and added to the Tool Crib.
When this check
box is cleared, you can edit all tool information directly in the dialog
box. In this case, the defined tool is added to the Tool Crib.
Note: Although the Machining Data group remains the same regardless of the tool selected, The available Tool Data, and the Speed and Feed parameters vary depending on the type of tool selected. Click on a tool to display the Tool Data for that particular tool. Once open, click on Machining Data and Feeds and Speeds to see the corresponding variables.
Drill
Center Drill
Machining Data
Tool Number - opens the Assigned Tools dialog box for you to change the tool numbering.
Override Offsets
Clear the Override Offsets check box to use the tool number to set the
Offset Register value.
Select the Override Offsets check box to allow for manual editing of the
- Height Offset - sets
the Height Offset to be used in the posted program.
- Diameter Offset - sets the Diameter Offset to used in the posted program.
- Coolant - sets the coolant option for the operation. Select one of the following options: Off, Flood, Mist, Air, or Oil.
Feeds and Speeds
Use System Feeds and Speeds
Select this check
box to automatically calculate the feeds and speeds.
Clear this check
box to type feeds and speeds values in the dialog box.
- SFM/SMM - is the surface feet/meters per minute feedrate.
- Plunge Feed per Tooth - sets the rate of depth per tooth. The value is linked to the Plunge Feedrate.
- Spindle RPM - is the revolutions per minute of the spindle.
- Plunge Feedrate - is the downward feedrate. This value is linked to the Plunge Feed per Tooth.
Dwell - sets the amount of seconds to Dwell.
Note: While editing the feeds and speeds, changing one value automatically calculates any other associated values. For example, if you modify the SFM value, the Spindle RPM, Cutting Feedrate, and Plunge Feedrate are automatically calculated.
Drill
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
- Feed per Minute - is the feedrate for the tap in feed per minute.
- Feed per Revolution - is the total depth per revolution.
Spiral Tap
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Point Tap
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Hand Tap
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Rolling Tap
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Chamfer Tool
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Counterbore
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Reamer
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Boring
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Mill
Endmill Rough
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
- Feed per Tooth - is the feedrate for feed moves in units per tooth.
- Plunge Feed per Tooth - is the feedrate for plunge moves in units per tooth.
- Cutting Feedrate - is the feedrate for feed moves.
- Plunge Feedrate - is the feedrate for plunge moves.
- Arc Slowdown % - is the amount of the feedrate to use when in arc moves. 100% is equal to the Cutting Feedrate.
Endmill Finish
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Chamfer Mill
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Corner-Round
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Thread Mill
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Single Point Thread
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
V-Tool
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Tapered
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
T-Cutter
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Dove Mill
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Lollipop
Machining Data
Override Offsets
Feeds and Speeds
Select this check
Clear this check
Drag Knife
Machining Data
Override Offsets
Feeds and Speeds
Once the Tool variables have been set, clicking
will take you to the next page of the given operation.
To move the appropriate next topic, click the type of feature that has
been chosen below and then the link for the desired operation.
Center Drill Parameters
Drill Operation Parameters
Chamfer Drill Parameters
Chamfer Mill Patterns
Ream Parameters
Bore Parameters
Rolling Tap Parameters
Counterbore Drill Parameters
Counterbore Mill Parameters
Tap Parameters
Facing Patterns
Profile Rough Patterns
Profile Finish Patterns
Pocket Patterns
Facing Patterns
Engrave Parameters
Plunge Rough (2 Axis) Patterns
Corner Rounding Patterns
Z Level Rough Patterns
Z Level Finish Patterns
Planar Patterns
Spiral Patterns
Radial Patterns
Plunge Rough Patterns
Advanced Rough Patterns
Flatlands Parameters
Equidistant Patterns
Pencil Parameters
Advanced Planar Patterns
Project Curves Patterns
Advanced Z Level Finish Patterns
4 Axis Rotary Patterns
Mill Thread Pattern
3 Axis Wireframe Parameters
