This topic will explain the Patterns page of the Lathe Rough operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
Depth of Cut - sets the spacing between toolpath passes.
Rough Allowance -  Selecting this option will create a pass before the final pass to act as a semi-finish. The spacing of the semi-finish pass will be dictated by the values entered in the Z and X boxes.
No Allowance
Finish Allowance
Rough & Finish
No Allowance Simulation
Finish Allowance Simulation
Rough & Finish  Simulation
*Steps can also be eliminated with the Overlap options below.
Overlap
The Overlap options allow you to create an additional move prior to the link to the next pass. This link will track back up the geometry in order to eliminate stair steps as seen in the images above. Overlap is controlled with either, To Previous Cut, No Overlap, or Custom Distance.
To Previous Cut - automatically tracks back up the geometry the distance of the selected depth of cut.
No Overlap - does not track back up the geometry at all.
Custom Distance - Allows you to enter a custom distance value. This value is a vertical distance. Entering the same value that has been entered for the depth of cut will track back to the last cut exactly.
Chip Break
The option allows you to create minute retract moves, at user specified intervals, to aid in chip breaking.
Chip Break... - With this option cleared, the toolpath will not include chip break moves.
Chip Break... -  With this option selected, the toolpath will include chip break moves that can be modified in the Chip Break dialog. Click the Chip Break button to enter the dialog.
Chip Break... Chip Break...
This group allows you to determine how the intervals between retracts should be defined.
  • Length of cut - The retracts are determined by the amount of space between them.
  • Time - The retracts are determined by the amount of time between them.
  • Length of chip - The retracts are determined by the amount of material being removed between them.
Retract
  • Retract distance - sets the length of the retract move used to break chips.
Corner Type
Round - keeps the specified tool geometry in contact with the geometry at all times.
Sharp - allows the tool to move off the geometry in order to line up with the next move on the following entity. This method eliminates the rounding over of the tool.
Theoretical Point on Tool
Rounded Corner
Sharp Corner
Bounds
Trim to Stock -  With this option selected, the toolpath that extends beyond the Operation Stock will be trimmed away.
