The Mill 2 Axis Wizard Posting Settings
The fourth step of the Milling Wizard is to define a few posting parameters for the feature. This includes the work offset number, indexing output, and a few tolerance settings for the output program code. For Mill Turn jobs, the posting mode and submachine settings also display.
Posting
Posting Parameters
Work Offset # - select the work offset code to use for this feature in the posted NC program. The post processor must be configured to support the work offset selected.
Note: The Output Rotary Angle option is only available with the 4 Axis Standard, 4 Axis Pro, 5 Axis Standard, and 5 Axis Pro modules. These parameters are used to create indexing programs without using index systems.
- Output Rotary Angle
Select the check box to have the Rotation Angle output in the posted NC program.
Clear the check box when not outputting a rotary angle.
- Rotation Angle - type the rotary angle of the feature for indexing.
Contour Ramping Output
Line Moves - the toolpath is output as linear segments. This option is used if the machine controller does not accept helical arc segments.
Arc Moves - the toolpath output includes helical arc segments.
Click
here to see the Mill Turn Posting Settings
If the machine selected for the job has 3 or fewer axis, click Next>> to go to Tool Page.
If the machine selected for the job has 4 or more axis, click Next>> to go to The
Multiaxis Posting Dialog Box.
