This topic explains the Parameters page of the Project Curves operation found in the 3 Axis Wizard.
Finish
Stepover
- Stepover - defines the distance between each pass in X and Y, or the XY plane.
- Machining
Tolerance - the amount of variation allowed for creating the
toolpath for the feature. The accuracy of the toolpath does not exceed
this range.
Cut Holes - extends the toolpath into any holes
that may be present in the surface.
- Ignore Holes - does not place the toolpath into any holes and treats the surface as if it is continuous and unbroken.
Depth Options
- Top of Job
- sets the highest Z location for toolpath as the top of stock.
- allow you to specify the highest Z location for toolpath in this operation. Select the check box and type a value to define a plane for the top of job.- Pick - hides the Wizard to allow
you to set the Top of Job by selecting geometry whose height, in relation to the machine setup, is at the desired value.
- Bottom of Job
- sets the lowest Z location for toolpath as the bottom of stock.
- allows you to specify the lowest Z location for toolpath in this operation. Select the check box and type a value to define a plane for the bottom of job.- Pick - hides the Wizard to allow you to set the Top of Job by selecting geometry whose height, in relation to the machine setup, is at the desired value.
Note: The Bottom of Job and Top of Job values are in reference to the machining origin (Machine Setup coordinate) of the part.
Allowance
The Allowance settings are used to define the rest material, or the amount of material remaining after this operation to be removed by the next operation, in one of two ways. These options offset the model geometry to calculate the toolpath. You can use positive or negative values to leave extra material or cut deeper than the model geometry, respectively.
Offset Type
The Offset Type determines if the allowance is applied to the entire model or separately for the bottom and sides of the part. Select one of the following options and then type the allowance value in the available allowance boxes.
- Global
- applies a single allowance value to the entire model using the Allowance
XYZ value.
- Side
and Bottom - allows you to specify separate allowances for
the side (XY) and bottom (Z) of the part.
- Advanced - opens the Allowances dialog to allow you to select surfaces to assign as either Part, or Fixture, geometry items. Each of those items can then have specific allowances set.
- With this check box cleared, only the Offset Type and Allowance above will be used for the Feature Geometry.
- With this check box selected, the geometry and allowances set in the (Advanced) Allowances dialog will be active.
Bounds
The Trim to Stock option provides the ability to pass the stock definition to the toolpath calculation, which trims the toolpath to remove air cutting. You can assign stock geometry (.stl or solid model) to the Operation Stock item in the CAM Tree, or if you do not assign operation stock, the software uses the stock definition from the Stock Wizard. This option can be used as a 3D boundary for the operation.
Important: In order to pass a stock definition to the toolpath calculation, you must turn on Trim to Stock in the wizard as explained next. If you assign Operation Stock, but do not turn on Trim to Stock, the stock isn't used in the toolpath calculation.
- Trim to
Stock
- Clear the check box to create the operation without trimming the toolpath to the stock.
- Select the check box when you want the software to trim the toolpath for the operation to the stock in one of two ways. You can (1) assign a solid model or .stl file using the Operation Stock item in the CAM Tree, or (2) if you don't assign operation stock, the software automatically uses the stock from the Stock Wizard to trim the toolpath. View Selecting Operation Stock.
Tip: You
can use simulation to save the stock model as an .stl file, which can
then be used as Operation Stock. To learn more, view How
to Save Simulation Stock as STL.
