Milling Tools
This topic will explain the Milling Tools item as it appears in the CAM Tree, and the option in its context menu. This topic will also provide links to related topics.
The Milling Tools
Right-click Milling Tools to open a context menu with the following commands.
Milling Tools
    • Tools - opens the Tool Library showing the available system tools. You can create or modify tools from this location.
    • Tool Crib - opens the Tool Crib for you to load all of the tools that you need for the job.
    • Mill Tool Holders - opens the Milling Tool Holder Library for you to create and/or modify the milling tool holders and arbors.
    • Verify Tool Assignment - displays the Assigned Tools dialog box containing all of the tools that are currently used in the program. The tool numbers used in the software may not match the tools as they are listed on the machine, so this item is provided so that you can reassign those numbers to reflect what is actually used in your shop.
For information on tools, follow these links:
Tool Library
Tool Crib
Assigned Tools
The Milling Tool Holder Library
Click here to go to the Stock Wizard Overview topic.
