Emboss from Surface/Solid Example 1
This topic explains how to create an Emboss from Surface/Solid feature. In this example, you learn three ways to handle the placement of the solid or surface on the model.
The part file for this tutorial is available for download at: http://www.bobcad.com/helpfiles. If you are connected to the Internet, you can click the link provided to download and save the Emboss from Surface Example 1.SLDPRT zip file. After downloading the zip file, extract the files on your system in a place that is easy to remember. You can then open the file to use with this tutorial.
In this example, an acoustic guitar has already been created, and three features remain that are created using solid bodies. The current condition of the model is shown next.
Part 1) Open the Example File
in the Quick Access Toolbar, click Open.
In the Open dialog box, select the folder in which you saved the example file.
Select Emboss from Surface Example 1.sldprt, and click Open.
The file is opened, and the model displays in the graphics area. -
In the Manager Pane, click the BobART Manager tab.
Part 2) Add the Feature (Use Current Position and Adjust the Height)
For the first feature in this example, a truss-rod cover is added to the model. For this feature, the geometry is currently located in the correct position in the XY plane, but it is not in the final Z-axis position. The bottom of the solid is at Z0. For this feature, the current position of the solid is used, and then the vertical (Z-axis) position is adjusted as needed.
In the BobART tree, right-click Emboss Model, and click Emboss from Surface/Solid.
The Create Emboss from Surface dialog box displays. -
In the Emboss Attributes group, in the Name box, select the text and type Truss Rod Cover.
Confirm that the Application Type is set to Add.
Click Color. In the Color dialog box, click an orange color for the feature, and click OK.
To close the dialog box and add the feature to the BobART tree, click OK.
Part 3) Select Geometry and Edit the Feature
When the Create Emboss from Surface dialog box was closed, the emboss feature was added to the BobART tree. You use the Feature in the BobART Tree to select geometry and to edit the feature.
In the BobART tree, under Trust Rod Cover, right-click Geometry, and click Re/Select.
Expand the Feature Manager design tree in the graphics area (if needed), and select the Truss Rod Cover feature. (For reference, the second image shows the solid we are selecting, which is hidden by the embossed model.)
To confirm the selection, click .
Tip: When selecting geometry for an Emboss from Surface/Solid feature, you can select individual surfaces or an entire solid. The selection method shown in the previous steps selected the entire solid. We could have selected only the top surface of the solid to achieve the same result.
Notice there is no change in the model yet. We must regenerate to update the changes.
Before regenerating, there is one more change we need to make in the feature. The origin (lower-left corner of the solid) is currently set to X0 Y0 Z0, but we want to use the position in which we created the solid.
To edit the feature, in the BobART tree, right-click Truss Rod Cover and click Edit.
In the Create Emboss from Surface dialog box, click Use Surface Position.
Notice that the XYZ values in the Origin group are automatically set based on the selected geometry.
Note: The Origin (XYZ) values are in reference to the selected coordinate system origin for the BobART model. For this example, we used the WCS or SolidWorks World Coordinate System.
To close the dialog box, click OK.
Part 4) Regenerate to Update the Model
To add the feature to the model, right-click Emboss Model, and click Regenerate.
Notice, as shown in the second image, the feature is being added to the strings. This is the result of the Add application type. The cover needs added to the head stock but not the strings. For this, we change the application type and adjust the Z-axis height of the solid. -
Right-click Truss Rod Cover, and click Edit.
In the Create Emboss from Surface dialog box, click the Application Type arrow, and click Merge High.
Because the solid (bottom) is located at Z0 and the application type is set to merge high, the Z-axis value of the origin must be increased to move the solid up to the proper level on the mode.
In the Origin group, set the Z value to 0.725.
Click OK. -
To update the changes, right-click Emboss Model and click Regenerate.
The first feature is now complete. In the next part of this tutorial, you emboss from a solid that is oriented in the graphics area in the exact location that it is needed for the model.
Part 5) Emboss from Solid Using the Exact Model Location
In this part of the tutorial, the solid for the feature is placed at the exact location that it is needed. By placing the solid geometry before creating the feature, less parameters need to be changed to create the desired result.
In the Feature Manager design tree, right-click the CAD feature name Nut, and click (Show).
The solid displays in the graphics area. -
In the BobART tree, right-click Emboss Model, and click Emboss fromSurface/Solid.
Change the Application Type to Merge High.
In the Name box, type the name Nut Emboss.
Click Color.
In the Color dialog box, click the white color for the feature, and click OK.
To close the dialog box and add the feature to the BobART tree, click OK. -
In the BobART tree, under Nut Emboss, right-click Geometry, and click Re/Select.
In the Feature Manager design tree, click to select the Nut feature.
To confirm the selection, click . -
In the Feature Manager design tree, right-click the CAD feature name Nut, and click (Hide).
In the BobART tree, right-click Nut Emboss, and click Edit.
Click Use Surface Position. (The XYZ Origin values are automatically set.)
Click OK to close the dialog box. -
Right-click Emboss Model, and click Regenerate.
Part 6) Add the Third Feature - Use the Origin to Place the Solid
You may want to use a solid/surface this is at an arbitrary location in the workspace. In this case, you can use the origin of the solid/surface to place the feature on the model. This is shown in this part of the example when a pick guard is added to the model. The location of the solid (pick guard) and the model are shown next.
For organic shapes (or any shape), the origin (reference point) is the lower-left corner of a bounding box drawn around the entity. The pick guard (solid) and its origin (red point) are shown in the next image.
When setting the location of a surface/solid, the XYZ values of the (surface/solid) origin specify the distance from the coordinate system selected for the emboss model. The origin location of the pick guard on the model is shown in the next image.
Right-click Emboss Model, and click Emboss from Surface/Solid.
Make the following changes In the Create Emboss from Surface dialog box.
Under Origin:
X = 15.227
Y = 14.419
Z = 0.750.
Application Type = Merge High.
Type the name (Pick Guard) and select a color for the feature.
Right-click Geometry, and click Re/Select.
Select the Pick Guard feature from the design tree.
Note that as mentioned earlier, you could also drag a window to select the surfaces directly from the graphics area, but this method does not select the entire solid (the bottom face is omitted). Another way to select the entire solid is to use the Select Whole Bodies option in the Selection Manager.
Regenerate to add the pick guard emboss to the model.
Final Note - Model Resolution
Be sure to view Adjusting Resolution for Emboss Models.
This concludes the tutorial.
