GetDoubleOfPostVariable() : Working Variables
The API GetDoubleOfPostVariable() , works with many variables, but not all. This topic lists all working variables for the GetDoubleOfPostVariable() API, listed by variable type.
Working Variables
Positioning
Mill Job |
This outputs the initial primary rotation axis angle value for rotary and 5 axis motion. The output is formatted with the prefix defined on post question: 722 API: GetDoubleOfPostVariable(“variable_name”) |
Mill Turn Job |
Mill Job |
This outputs the initial secondary rotation axis angle value for rotary and 5 axis motion. The output is formatted with the prefix defined on post question: 723 API: GetDoubleOfPostVariable(“variable_name”) |
Mill Turn Job |
Mill Job |
This outputs the initial tertiary rotation axis angle value for rotary and 5 axis motion. The output is formatted with the prefix defined on post question: 724 API: GetDoubleOfPostVariable(“variable_name”) |
Mill Turn Job |
Mill Job |
Outputs the first X position of the operation in Machine Hybrid Compensation(Mixed Mode) Move list coordinates mode. Prefix is defined in the post question 684.
NOTE - To be ideally used in start, tool change, null tool change, 30 & 31 blocks and useful in cases where coordinates output should not be in TCP before calling to turn on TCP
Mill Turn Job |
Mill Job |
Outputs the first Y position of the operation in Machine Hybrid Compensation(Mixed Mode) Move list coordinates mode. Prefix is defined in the post question 685.
Mill Turn Job |
Mill Job |
Outputs the first Z position of the operation in Machine Hybrid Compensation(Mixed Mode) Move list coordinates mode. Prefix is defined in the post question 686.
Mill Turn Job |
Mill Job |
Outputs the first X position of the operation in No Machine Compensation Move list coordinates mode. Prefix is defined in the post question 684.
Mill Turn Job |
Mill Job |
Outputs the first Y position of the operation in No Machine Compensation Move list coordinates mode. Prefix is defined in the post question 685.
Mill Turn Job |
Mill Job |
Outputs the first Z position of the operation in No Machine Compensation Move list coordinates mode. Prefix is defined in the post question 686.
Mill Turn Job |
Mill Job |
Outputs the first X position of the operation in Origin Tracking Move list coordinates mode. Prefix is defined in the post question 684.
Mill Turn Job |
Mill Job |
Outputs the first Y position of the operation in Origin Tracking Move list coordinates mode. Prefix is defined in the post question 685.
Mill Turn Job |
Mill Job |
Outputs the first Z position of the operation in Origin Tracking Move list coordinates mode. Prefix is defined in the post question 686.
Mill Turn Job |
Mill Job |
Outputs the first X position of the operation in Part Based (Common for TCP) Move list coordinates mode. Prefix is defined in the post question 684.
Mill Turn Job |
Mill Job |
Outputs the first Y position of the operation in Part Based (Common for TCP) Move list coordinates mode. Prefix is defined in the post question 685.
Mill Turn Job |
Mill Job |
Outputs the first Z position of the operation in Part Based (Common for TCP) Move list coordinates mode. Prefix is defined in the post question 686.
Mill Turn Job |
Mill Job |
Outputs the first X position of the operation based on the previous operation Move list coordinates mode. If its first operation, outputs coordinates as No Machine Compensation mode. Prefix is defined in the post question 684. NOTE - To be ideally used in start, tool change, null tool change, 30& 31 blocks and useful in cases where coordinates output should not be in TCP before calling to turn on TCP
API : GetDoubleOfPostVariable(“variable_name”) |
Mill Turn Job |
Mill Job |
Outputs the first Y position of the operation based on the previous operation Move list coordinates mode. If its first operation, outputs coordinates as No Machine Compensation mode. Prefix is defined in the post question 685.
Mill Turn Job |
Mill Job |
Outputs the first Z position of the operation based on the previous operation Move list coordinates mode. If its first operation, outputs coordinates as No Machine Compensation mode. Prefix is defined in the post question 686.
Mill Turn Job |
Mill Job |
Outputs the first X position of the operation in Machine Compensation in Z only Move list coordinates mode. Prefix is defined in the post question 684.
Mill Turn Job |
Mill Job |
Outputs the first Y position of the operation in Machine Compensation in Z only Move list coordinates mode. Prefix is defined in the post question 685.
Mill Turn Job |
Mill Job |
Outputs the first Z position of the operation in Machine Compensation in Z only Move list coordinates mode. Prefix is defined in the post question 686.
Mill Turn Job |
Mill Job |
Returns the value of the previous X axis feed move. Rapid moves are not included. Prefix comes from the post question: 684 |
Lathe Job
Mill Turn Job |
The prefix is defined by the post mapping section of the post processor. The devices have their prefixes defined based on DeviceID. The prefix mapping blocks are 5000 through 5049 for absolute, and 5050 through 5099 for incremental. If prefix is not defined in prefix mapping blocks, then prefix from post question 684 will be used.
API: double MILLTURN_GetPreviousXFeed() |
Mill Job |
Returns the value of the previous Y axis feed move. Rapid moves are not included. Prefix comes from the post question: 685 |
Mill Turn Job |
The prefix is defined by the post mapping section of the post processor. The devices have their prefixes defined based on DeviceID. The prefix mapping blocks are 5000 through 5049 for absolute, and 5050 through 5099 for incremental. If prefix is not defined in prefix mapping blocks, then prefix from post question 685 will be used.
API: double MILLTURN_GetPreviousYFeed() |
Mill Job |
Returns the value of the previous Z axis feed move. Rapid moves are not included. Prefix comes from the post question: 686 |
Lathe Job
Mill Turn Job |
The prefix is defined by the post mapping section of the post processor. The devices have their prefixes defined based on DeviceID. The prefix mapping blocks are 5000 through 5049 for absolute, and 5050 through 5099 for incremental. If prefix is not defined in prefix mapping blocks, then prefix from post question 686 will be used.
API: double MILLTURN_GetPreviousZFeed() |
Mill Job |
Outputs the rotation angle from wrapping blocks using the prefix defined on post question: 690 for X axis wrapping and post question 694 for Y axis wrapping. |
Mill Turn Job |
This variable has been replaced by p_rot and s_rot variables. |
rotary_xyr_angle
Mill Job |
Outputs the rotation angle from wrapping blocks using the prefix defined on post question: 684 for X axis and 685 for Y axis. |
Mill Job |
Mill Job |
Outputs the rotation angle from wrapping blocks using prefix from post question: 690 |
Mill Turn Job |
Mill Job |
Outputs the rotation angle from wrapping blocks using prefix from post question: 694 |
Mill Turn Job |
Mill Job |
Returns the value of the current X axis feed move. Prefix comes from the post question: 684 |
Lathe Job
Mill Turn Job |
API: double MILLTURN_GetXFeed() |
Mill Job |
Returns the value of the current Y axis feed move. Prefix comes from the post question: 685 |
Lathe Job
Mill Turn Job |
API: double MILLTURN_GetYFeed() |
Mill Job |
Returns the value of the current Z axis feed move. Prefix comes from the post question: 686 |
Lathe Job
Mill Turn Job |
API: double MILLTURN_GetZFeed() |
Mill Job |
Returns the X axis rapid location with the prefix defined by post question: 684 |
Lathe Job |
Mill Turn Job |
Returns the X axis rapid location with the prefix defined by the post mapping section of the post processor. The devices have their prefixes defined based on DeviceID. The prefix mapping blocks are 5000 through 5049 for absolute, and 5050 through 5099 for incremental. If prefix is not defined in prefix mapping blocks, then prefix from post question 684 will be used.
API: double MILL_GetXRapid() double LATHE_GetXRapid() |
Mill Job |
Returns the Y axis rapid location with the prefix defined by post question: 685 |
Lathe Job |
Mill Turn Job |
Returns the Y axis rapid location with the prefix defined by the post mapping section of the post processor. The devices have their prefixes defined based on DeviceID. The prefix mapping blocks are 5000 through 5049 for absolute, and 5050 through 5099 for incremental. If prefix is not defined in prefix mapping blocks, then prefix from post question 685 will be used.
API: double MILL_GetYRapid() double LATHE_GetYRapid() |
Mill Job |
Returns the Z axis rapid location with the prefix defined by post question: 686 |
Lathe Job |
Mill Turn Job |
Returns the Z axis rapid location with the prefix defined by the post mapping section of the post processor.
API: double MILL_GetZRapid() double LATHE_GetZRapid() |
Transform Plane
euler_angle_zxz_intrinsic_2 euler_angle_zxz_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by intrinsic rotation around machine setup Z axis first, then around X axis of the rotated coordinate system resulted from first rotation & finally around Z axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
euler_angle_zxz_extrinsic_2 euler_angle_zxz_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by extrinsic rotation around the machine setup Z axis first, X axis & Z axis again for the transformed plane |
Mill Turn Job |
euler_angle_xyx_intrinsic_2 euler_angle_xyx_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by intrinsic rotation around machine setup X axis first, then around Y axis of the rotated coordinate system resulted from first rotation & finally around X axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
euler_angle_xyx_extrinsic_1 euler_angle_xyx_extrinsic_2 euler_angle_xyx_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by extrinsic rotation around X axis, Y axis, X axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
euler_angle_yzy_intrinsic_2 euler_angle_yzy_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by intrinsic rotation around machine setup Y axis first, then around Z axis of the rotated coordinate system resulted from first rotation & finally around Y axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
euler_angle_yzy_extrinsic_2 euler_angle_yzy_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by extrinsic rotation around Y axis, Z axis, Y axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
euler_angle_zyz_intrinsic_2 euler_angle_zyz_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by intrinsic rotation around machine setup Z axis first, then around Y axis of the rotated coordinate system resulted from first rotation & finally around Z axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
euler_angle_zyz_extrinsic_2 euler_angle_zyz_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by extrinsic rotation around Z axis, Y axis, Z axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
euler_angle_xzx_intrinsic_2 euler_angle_xzx_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by intrinsic rotation around machine setup X axis first, then around Z axis of the rotated coordinate system resulted from first rotation & finally around X axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
euler_angle_xzx_extrinsic_2 euler_angle_xzx_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by extrinsic rotation around X axis, Z axis, X axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
euler_angle_yxy_intrinsic_2 euler_angle_yxy_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by intrinsic rotation around machine setup Y axis first, then around X axis of the rotated coordinate system resulted from first rotation & finally around Y axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
euler_angle_yxy_extrinsic_2 euler_angle_yxy_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Euler angle definition by extrinsic rotation around Y axis, X axis, Y axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
rpy_angle_xyz_intrinsic_2 rpy_angle_xyz_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by intrinsic rotation around machine setup X axis first, then around Y axis of the rotated coordinate system resulted from first rotation & finally around Z axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
rpy_angle_xyz_extrinsic_2 rpy_angle_xyz_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by extrinsic rotation around X axis, Y axis, Z axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
rpy_angle_yzx_intrinsic_2 rpy_angle_yzx_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by intrinsic rotation around machine setup Y axis first, then around Z axis of the rotated coordinate system resulted from first rotation & finally around X axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
rpy_angle_yzx_extrinsic_2 rpy_angle_yzx_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by extrinsic rotation around Y axis, Z axis, X axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
rpy_angle_zxy_intrinsic_2 rpy_angle_zxy_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by intrinsic rotation around machine setup Z axis first, then around X axis of the rotated coordinate system resulted from first rotation & finally around Y axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
rpy_angle_zxy_extrinsic_2 rpy_angle_zxy_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by extrinsic rotation around Z axis, X axis, Y axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
rpy_angle_xzy_intrinsic_2 rpy_angle_xzy_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by intrinsic rotation around machine setup X axis first, then around Z axis of the rotated coordinate system resulted from first rotation & finally around Y axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
rpy_angle_xzy_extrinsic_2 rpy_angle_xzy_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by extrinsic rotation around X axis, Z axis, Y axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
rpy_angle_zyx_intrinsic_2 rpy_angle_zyx_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by intrinsic rotation around machine setup Z axis first, then around Y axis of the rotated coordinate system resulted from first rotation & finally around X axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
rpy_angle_zyx_extrinsic_2 rpy_angle_zyx_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by extrinsic rotation around Z axis, Y axis, X axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
rpy_angle_yxz_intrinsic_2 rpy_angle_yxz_intrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by intrinsic rotation around machine setup Y axis first, then around X axis of the rotated coordinate system resulted from first rotation & finally around Z axis of the rotated coordinate system resulted from the second rotation respectively for the transformed plane |
Mill Turn Job |
rpy_angle_yxz_extrinsic_2 rpy_angle_yxz_extrinsic_3 |
Mill Job |
Outputs the rotation angles for Roll Pitch Yaw angle definition by extrinsic rotation around Y axis, X axis, Z axis respectively of the machine setup for the transformed plane |
Mill Turn Job |
Mill Job |
Outputs the coordinate of the origin for the transformed plane from the machine setup position along the first translation axis (Typically the X axis origin) |
Mill Turn Job |
Mill Job |
Outputs the coordinate of the origin for the transformed plane from the machine setup position along the second translation axis (Typically the Y axis origin) |
Mill Turn Job |
Mill Job |
Outputs the coordinate of the origin for the transformed plane from the machine setup position along the third translation axis (Typically the Z axis origin) |
Mill Turn Job |
transform_plane_dir_x_2 transform_plane_dir_x_3 |
Mill Job |
Outputs the first vector I,J,K for the transform plane when using 2 vectors definition for transform planes |
Mill Turn Job |
transform_plane_dir_z_2 transform_plane_dir_z_3 |
Mill Job |
Outputs the second vector I,J,K for the transform plane when using 2 vectors definition for transform planes |
Mill Turn Job |
transform_plane_pnt_2_2 transform_plane_pnt_2_3 |
Mill Job |
Outputs X,Y,Z coordinates along the X axis of the transformed plane relative to the origin of the machine setup. Note: The transform_plane_origin_# variables are typically used for the first point of the 3 point transform plane output. |
Mill Turn Job |
transform_plane_pnt_3_2 transform_plane_pnt_3_3 |
Mill Job |
Outputs X,Y,Z coordinates along the Y axis of the transformed plane relative to the origin of the machine setup. |
Mill Turn Job |
transform_plane_orientation_y transform_plane_orientation_z |
Mill Job |
Outputs the I,J,K values for the Z axis of the transformed plane. |
Mill Turn Job |
Mill Job |
Outputs first rotary angle for the operations on the transform plane. |
Mill Turn Job |
Mill Job |
Outputs second rotary angle for the operations on the transform plane. |
Mill Turn Job |
Mill Job |
Outputs third rotary angle for the operations on the transform plane. |
Mill Turn Job |
Mill Job |
Outputs the X axis rapid location on the transformed plane with the prefix defined by post question: 684
This variable should be used in block 31 to output coordinates relative to the transformed plane |
Mill Turn Job |
Mill Job |
Outputs the Y axis rapid location on the transformed plane with the prefix defined by post question: 685 This variable should be used in block 31 to output coordinates relative to the transformed plane |
Mill Turn Job |
Mill Job |
Outputs the Z axis rapid location on the transformed plane with the prefix defined by post question: 686 This variable should be used in block 31 to output coordinates relative to the transformed plane |
Mill Turn Job |
Probing Cycle Variables - Cycle Definitions
Probing measure cycle parameters
Mill Job |
This variable will output the string defined on post question: 4250. used for defining the prefix for the X axis position moves when probing.
Example String Values are:
Mill Job |
This variable will output the string defined on post question: 4251. used for defining the prefix for the Y axis position moves when probing.
Mill Job |
This variable will output the string defined on post question: 4252. used for defining the prefix for the Z axis position moves when probing.
Mill Job |
This variable will output the string defined on post question: 4253. used for defining the prefix for the bore and boss diameter parameter when probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4254. used for defining the prefix for the angle parameter when probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4255. used for defining the prefix for the angle parameter when probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4256. used for defining the prefix for the angle parameter when probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4257. used for defining the prefix for the angle parameter when probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4258. used for defining the prefix for the distance parameter when probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4259. used for defining the prefix for the X distance parameter when corner probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4260. used for defining the prefix for the Y distance parameter when corner probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4261. used for defining the prefix for the second X distance parameter when corner probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4262. used for defining the prefix for the second Y distance parameter when corner probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4263. used for defining the prefix for the X distance parameter in 4th axis probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4264. used for defining the prefix for the Y distance parameter in 4th axis probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4265. used for defining the prefix for the X length in rectangle probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4266. used for defining the prefix for the Y length in rectangle probing.
Used In:
Mill Job |
This variable will output the string defined on post question: 4267. used for defining the prefix for the Z measure position parameter in a Pitch Circle Diameter Bore cycle.
Used In:
Mill Job |
This variable will output the string defined on post question: 4268. used for defining the prefix for the face for 2 measurements parameter in the rectangle probing cycle.
Used In:
Mill Job |
This variable will output the string defined on post question: 4269. used for defining the prefix for the P2 & P4 measure position parameters in the rectangle probing cycle.
Used In:
Mill Job |
This variable will output the string defined on post question: 4270. used for defining the prefix for the distance between 2 points in the rectangle probing cycle.
Used In:
Mill Job |
This variable will output the string defined on post question: 4271. used for defining the second distance parameter in rectangle probing cycle.
Used In:
Mill Job |
This variable will output the string defined on post question: 4272. used for defining the probe surface output parameter.
Used In:
Mill Job |
This variable will output the string defined on post question: 4273. used for defining the 4th axis probing type parameter.
Used In:
Mill Job |
This variable will output the string defined on post question: 4274. used for defining the pitch circle diameter parameter in PCD cycles.
Used In:
Mill Job |
This variable will output the string defined on post question: 4275. used for defining the number of features in PCD cycles.
Used In:
Optional Parameters
Mill Job |
This variable will output the string defined on post question: 4276. used for defining the angle tolerance parameter in probing cycles.
Used In:
Mill Job |
This variable will output the string defined on post question: 4277. used for defining the probe experience value parameter in probing cycles.
Used In:
Mill Job |
This variable will output the string defined on post question: 4278. used for defining the probe feedback parameter in probing cycles.
Mill Job |
This variable will output the string defined on post question: 4279. used for defining the tolerance value of feature dimensioning in probing cycle.
Mill Job |
This variable will output the string defined on post question: 4280. used for defining the true position tolerance of a feature in probing cycle.
Mill Job |
This variable will output the string defined on post question: 4281. used for defining the probe overtravel distance in probing. (Default when excluded is 4mm in Z axis, and 10mm in X/Y axes.
Mill Job |
This variable will output the string defined on post question: 4282. used for defining the incremental distance for external features prior to Z moves. Default distance is 5mm.
Mill Job |
This variable will output the string defined on post question: 4283. used for defining the work offset that is to be updated (S1-S6 for G54-G59, S101-S400 for additional offsets.
Mill Job |
This variable will output the string defined on post question: 4284. used for defining the tool offset that is to be updated.
Mill Job |
This variable will output the string defined on post question: 4285. used for defining the upper tolerance limit used in tool setting.
Mill Job |
This variable will output the string defined on post question: 4286. used for defining the null band used in tool setting. (Tolerance limit for adjusting tool offset)
Mill Job |
This variable will output the string defined on post question: 4287. used for printing the output data (W1 or W2)
Contact Tool Setter Cycle Parameter Variables
Mill Job |
This variable will output the string defined on post question: 4420. used for defining the measurement type in a CTS cycle.
Mill Job |
This variable will output the string defined on post question: 4421. used for defining the tool diameter in a CTS cycle. NOTE: This forces the rotation of the tool on some machines.
Mill Job |
This variable will output the string defined on post question: 4422. used for defining the tool length tolerance value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4423. used for defining the length experience value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4424. used for defining the tool out of tolerance value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4425. used for defining the overtravel parameter value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4426. used for defining the tool offset parameter value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4427. used for defining the tool length parameter value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4428. used for defining the tool offset parameter value for Type A offset tables in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4429. used for defining the diameter experience value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4430. used for defining the extra z clearance parameter value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4431. used for defining the Z axis measure position parameter value in CTS cycles.
Mill Job |
This variable will output the string defined on post question: 4432. used for defining the incremental radial distance parameter value in the feed up cycle. .
Mill Job |
This variable will output the string defined on post question: 4433. used for defining the rapid position parameter in the Broken Tool cycle.
Mill Job |
This variable will output the string defined on post question: 4434. used for defining the clearance position parameter in the Broken Tool cycle.
Mill Job |
This variable will output the string defined on post question: 4435. used for defining the thermal comp cycle type parameter.
Mill Job |
This variable will output the string defined on post question: 4436. used for defining the thermal comp measure position parameter.
Mill Job |
This variable will output the string defined on post question: 4437. used for defining the thermal compX storage location parameter.
Mill Job |
This variable will output the string defined on post question: 4438. used for defining the thermal comp Y storage location parameter.
Mill Job |
This variable will output the string defined on post question: 4439. used for defining the thermal compZ storage location parameter.
Mill Job |
This variable will output the string defined on post question: 4440. used for defining the overtravel distance and radial clearance.
Non-Contact Tool Setter Cycle Parameter Variables
Mill Job |
This variable will output the string defined on post question: 4550. used for defining the prefix for the measurement type parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4551. used for defining the prefix for the tool length tolerance parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4552. used for defining the prefix for the length experience parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4553. used for defining the prefix for the out of tolerance parameter in broken NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4554. used for defining the prefix for the overtravel parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4555. used for defining the prefix for the spindle speed parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4556. used for defining the prefix for the tool offset parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4557. used for defining the prefix for the radial step-over parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4558. used for defining the prefix for the solid tool parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4559. used for defining the cutter edge parameter in NTS cycles. For when there are parts o f the tool or cutter edge, or when you want to use a slitting saw.
Mill Job |
This variable will output the string defined on post question: 4560. used for defining the prefix for the diameter offset number parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4561. used for defining the prefix for the diameter tolerance parameter in NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4562. used for defining the prefix for the step distance parameter in radial measure NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4563. used for defining the prefix for the radius/diameter experience parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4564. used for defining the prefix for the tool diameter parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4565. used for defining the prefix for the search distance for high spot parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4566. used for defining the prefix for the measure height parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4567. used for defining the prefix for the number of cutting edges parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4568. used for defining the prefix for the feed per rev parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4569. used for defining the prefix for the run-out tolerance parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4570. used for defining the prefix for the safety plane parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4571. used for defining the prefix for the start angle for profile checking parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4572. used for defining the prefix for the end angle for profile checking parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4573. used for defining the prefix for the profile checking height parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4574. used for defining the prefix for the profile checking linear distance parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4575. used for defining the prefix for the profile checking radial distance parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4576. used for defining the prefix for the work offset in thermal checking parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4577. used for defining the prefix for the tool length in thermal checking parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4578. used for defining the prefix for the corner radius parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4579. used for defining the prefix for the corner measure number of touches parameter NTS cycles.
Mill Job |
This variable will output the string defined on post question: 4580. used for defining the prefix for the corner measure radial measure option parameter NTS cycles.
Canned Cycles
Lathe Job |
Outputs the calculated chamfer distance in threading canned cycle. The value is calculated by Number of leads for canned cycle chamfer out multiplied by the pitch value. The prefix is defined on post question: 1799
API: GetDoubleOfPostVariable(thread_chamfer_distance)
Mill Turn Job |
Lathe Job |
Outputs the number of leads value specified for threading canned cycle chamfer out . The prefix is defined on post question: 1798.
API: GetDoubleOfPostVariable(thread_chamfer_numofleads)
Mill Turn Job |
Input Only Variables
These variables work as input for the GetDoubleOfPostVariable() API, but do not work as their own variable.
Mill Job |
Outputs the major Diameter value of the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
NOTE - This variable cannot be directly used inside a post processor since its only a variable that is a valid input to the GetDoubleOfPostVariable() API function |
Lathe Job |
Mill Turn Job |
Mill Job |
Outputs the minor Diameter value of the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
Lathe Job |
Mill Turn Job |
Mill Job |
Outputs the pitch value of the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
Lathe Job |
Mill Turn Job |
Mill Job |
Outputs the thread angle value of the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
Lathe Job |
Mill Turn Job |
Mill Job |
Outputs the taper angle value of the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
Lathe Job |
Mill Turn Job |
Mill Job |
Outputs the cutting hole size value for the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
Lathe Job |
Mill Turn Job |
Mill Job |
Outputs the rolling hole size value for the thread type used in tapping operation, only using the API GetDoubleOfPostVariable()
Lathe Job |
Mill Turn Job |
