Aerospace CNC Machining
CNC CAM Software for the Aerospace Engineering Industry
Aerospace components demand the highest quality standards. BobCAD-CAM delivers reliable 5-axis toolpaths, full machine simulation, and tight-tolerance strategies so you can machine complex parts with confidence” and get to first-cut faster.
Why Aerospace Shops Choose BobCAD-CAM
Complex multi-axis parts, long machining cycles, and zero tolerance for error — aerospace demands CAM software that delivers.
Choosing the right aerospace CNC CAM software starts with reliability and precision. BobCAD-CAM delivers efficient, verified toolpaths, full machine simulation so programs can be analyzed before cutting begins, and proven G-code for your specific machine tool and post processor — all at a price that makes sense for aerospace suppliers of any size.
5-Axis Simultaneous HSM Adaptive Roughing Full Machine Simulation Post Processor Support Surface Finishing Tight Tolerances
Aerospace Machining Capabilities in BobCAD-CAM
Purpose-built toolpaths for the part complexity, surface quality, and cycle-time demands of aerospace manufacturing.
High-Speed Adaptive Roughing
BobCAD-CAM’s HSM Adaptive Roughing delivers powerful material removal with efficient engagement” protecting tools, reducing cycle time, and improving finish quality on aerospace alloys. BobCAD-CAM was first to offer Multiaxis High-Speed Adaptive roughing for simultaneous 5-axis CNC machining.
5-AxisHSMRoughing
Z-Level Roughing & Rest Machining
Efficiently remove bulk material on complex 3D parts. The Advanced Roughing module adds an Intermediate Step that forces an additional cutting pass between Z levels” eliminating the staircase effect and leaving a uniform stock for finishing. Includes a dedicated REST roughing operation for corners and transitions.
3D RoughingRest Machining
Z-Level Finishing
Refine complex aerospace surfaces after roughing with Z-Level Finishing” a reliable strategy for cleaning up 3-axis parts and preparing surfaces for final inspection or coating.
Surface Finishing3-Axis
EquiDistant Finishing
Maintain a constant scallop height across any surface complexity. EquiDistant keeps the stepover uniform regardless of curvature changes” producing near-polished aerospace surfaces without secondary hand finishing. (Pro)
Constant ScallopPro
Swarf & Trimming (Multi-Axis)
Machine aerospace blades, brackets, and complex walls with Swarf toolpaths that keep the tool side engaged for cleaner cuts. Trimming strategies follow complex boundaries to maintain edge quality on aerospace flanges and pockets.
SwarfTrimming5-Axis
Verify every toolpath against your actual machine model before cutting begins. Detect collisions, overtravel, and unsafe transitions” essential for expensive aerospace billets where a single crash is unacceptable.
Collision DetectionSimulation
Flatlands & Pencil Finishing
Flatlands targets flat regions within complex surfaces for efficient planar finishing” ideal for aerospace mounting faces and datum surfaces. Pencil Finishing cleans up tight corners and blend regions where larger tools cannot reach.
FlatlandsPencilCleanup
Post Processor Reliability
Aerospace shops run demanding multi-axis machines. BobCAD-CAM’s post processor library and technician support ensures your G-code output matches your controller” so rotary motion, safe transitions, and TCPC output are correct from the start.
Post ProcessorMachine-Ready
What Aerospace Shops Say About BobCAD-CAM
Real feedback from aerospace engineers and CNC programmers.
“Aerospace components demand quality of the very highest standard. BobCAD-CAM is renowned for its reliability, producing efficient toolpaths and providing full simulation so toolpaths can be analyzed before machining takes place.”
” Aerospace Supplier, BobCAD-CAM Customer
“I found some of the things difficult to use. Later I upgraded and I can even begin to tell you how much nicer it was. BobCAD-CAM gives you the posts and will help you with them” and the training seminar made a huge difference in my ability to run the software.”
Aerospace-Grade CAM Without Aerospace-Grade Pricing
Premium multi-axis machining capability at a price point that works for job shops, OEM suppliers, and sub-contractors.
Proven on Complex Aerospace Geometry
From turbine brackets and engine housings to structural aircraft components, BobCAD-CAM’s 5-axis toolpaths handle the geometry complexity aerospace demands.
Structural PartsEngine Components
Reduce Programming Time by Up to 60%
Automated hole recognition, feature-based machining, and intelligent toolpath wizards dramatically reduce setup and programming time on high-complexity aerospace parts.
Faster ProgrammingFeature Recognition
US-Based Support for Critical Deadlines
When you’re running an aerospace program and need answers fast, BobCAD-CAM’s US-based technical team is available” including post processor support for your specific machine and controller.
US SupportPost Processor Help
Free, no-obligation demo
See BobCAD-CAM for Aerospace in Action
Talk to a specialist who understands aerospace CNC machining. We’ll demonstrate the toolpaths and simulation capabilities relevant to your parts” live, one-on-one, no obligation.
