CNC Router & Woodworking CAD CAM Software
CNC router software that allows you to build signs, cabinets, furniture, and creative projects with a complete CNC router software workflow. BobCAD-CAM combines woodworking CAD, router CAM toolpaths, and simulation so you can go from design to cutting with confidence. Create clean vectors for cutting, optimize sheet layouts for production, and use BobART to convert images into machinable geometry—including image-to-DXF vectors and detailed 3D relief carving for embossing.
Projects You Can Create with Woodworking CAM Software
From cabinetry and furniture to sign making and decorative carving, BobCAD-CAM woodworking CAM software gives shops the tools to build profitable projects with router-ready CAD/CAM toolpaths.
Cabinet, Furniture, and Flat Parts
Woodworking CAM software makes everyday production fast and repeatable. Create clean 2D toolpaths for profiles, pockets, drilling patterns, and repeat jobs — then post directly to your CNC router.
- Fast setup for everyday 2D routing
- Consistent results across repeat runs
- Great for “draw it, toolpath it, cut it” workflows
Signs, Logos, Lettering, and Decorative Panels
BobCAD-CAM woodworking CAM software includes BobART — turning logos, artwork, and clipart into cut-ready vectors for sign work, branding, plaques, and decorative features, all produced in-house.
Why it matters
When you can produce artistic work quickly, you can quote faster and deliver higher-value jobs.
3D Carving, Embossing, and STL Projects
Go beyond flat cutting with BobCAD-CAM’s 3D capabilities. Woodworking CAM software that supports emboss workflows and STL-based models — ideal for 3D reliefs, raised lettering, and carved product details.
- Emboss from solids or surfaces
- Work directly with STL models
- Reposition and modify to fit your project
Woodworking CAM Software Capabilities for CNC Routers
A complete workflow for CNC routers: design, toolpaths, simulation, and clean G-code output — BobCAD-CAM built for real shop production and artistic CNC router work alike.
Woodworking workflow (customer overview)
2D design + clean toolpaths for everyday routing Expand/Collapse
For production work, you want speed and repeatability. BobCAD-CAM woodworking CAM software supports common 2D routing workflows so you can program profiles, pockets, and repeat jobs quickly — with predictable G-code output at the machine and post processor options tailored to your controller.
- Strong 2D workflow for parts, fixtures, templates, and cutouts
- Simulation to validate moves before cutting material
- Post processor support to match your router and controller
BobART for artistic work (artwork → relief → toolpaths) Expand/Collapse
BobART is the artistic module built into BobCAD-CAM — converting artwork into geometry and toolpaths ideal for signs, logos, plaques, and decorative carving. It eliminates the need for a separate art CAM tool so woodworking shops can take on higher-value creative projects without switching platforms.
In plain terms
Bring in artwork, create a relief-style result, pick a toolpath, and cut.
- Perfect for signmaking, branding, decorative panels
- Great upsell path for shops currently doing only basic 2D cutting
3D / STL capability for carving and specialty projects Expand/Collapse
When you need more than 2D routing, BobCAD-CAM supports 3D workflows and STL-based models so you can handle carving projects, embossed reliefs, and shaped features with confidence. Great for 3-axis and 4-axis CNC router setups that need complex surface toolpaths.
- Emboss from solids or surfaces for raised/engraved effects
- STL handling for carving projects and imported models
- Works for 3-axis and 4-axis router setups
Turn Artwork into CNC Projects with BobCAD-CAM Woodworking CAM Software
BobCAD-CAM includes BobART — converting pictures, logos, and clipart into clean vectors for cutting or detailed 3D reliefs for carving and embossing. Ideal for signs, décor, and custom work that commands higher margins in woodworking CAM software workflows.
Convert images to machinable vectors
Use BobART — built into BobCAD-CAM woodworking CAM software — to turn logos, clipart, and pictures into vector geometry you can cut on a CNC router. Great for sign making, plaques, and decorative panels.
Create 3D embossing and relief carvings
Generate 3D reliefs from artwork and carve smooth contours for raised lettering, textures, and premium finishes—perfect for high-value custom projects.
Expand your service offerings
Spend less time in external design tools and more time producing. Add custom signage and artistic carving to increase job value and stand out.
Cut Cleaner and Faster — Efficiency Tools in BobCAD-CAM Woodworking CAM Software
Practical features built into BobCAD-CAM woodworking CAM software that reduce wasted motion, improve edge quality, and shorten cycle time — especially on CNC routers cutting wood, composites, and sheet goods.
Corner Slowdown
Slow down only where it matters—like sharp corners and direction changes—so you reduce vibration and chatter, protect tooling, and keep the rest of the job moving at speed.
Customer benefit
Cleaner corners + more consistent finish, with less stress on the tool and machine.
Minimize Retracts
Keep the tool down where it’s safe to do so—reducing unnecessary “up and down” moves and trimming air time. That means faster cycles and smoother motion.
Customer benefit
Less air cutting means shorter run times—especially on jobs with lots of features.
Extend Toolpath
Extend passes to create smoother transitions and more stable motion—helping your router keep cutting efficiently instead of stop/start behavior.
Customer benefit
Smoother motion can improve finish quality while reducing wasted time.
Woodworking CAM Software in Action — Videos & Demos
Watch BobCAD-CAM in action. These short videos cover BobART artistic workflows, efficiency features, and CNC router toolpath programming. Also see our Job Shop CAM Software and Fabrication Software pages for related capabilities.
Industries Using BobCAD-CAM Woodworking CAM Software
BobCAD-CAM woodworking CAM software serves production shops, custom fabricators, and creative studios across the woodworking and sign-making trades. Review industry benchmarks and best practices at Woodworking Network.
Cabinet Shops & Furniture Manufacturers
Cabinet shops and furniture manufacturers use woodworking CAM software to program profiles, dados, pocket drilling, and sheet-optimized cutting patterns for production CNC routers. BobCAD-CAM delivers the toolpath repeatability and post processor support these shops need to run parts consistently across shifts and machine setups. Also see our Job Shop CAM Software page for production-focused CAD-CAM workflows.
Sign Shops & Artistic CNC Studios
Sign shops and artistic CNC studios rely on woodworking CAM software to convert customer artwork, logos, and lettering into precision-cut results. BobART — built into BobCAD-CAM — lets these shops convert images directly into machinable vectors and 3D reliefs for carved signage, dimensional lettering, decorative panels, and high-value custom work that commands premium pricing.
Custom & Specialty CNC Shops
Custom CNC shops use woodworking CAM software to handle one-off projects, specialty fixtures, 3D carved components, and prototype work that doesn’t fit standard production templates. BobCAD-CAM’s integrated CAD and CAM tools let these shops design and program within the same system — reducing turnaround time on complex or one-of-a-kind pieces. Also see our Mold Machining CAM Software page for complex 3D surface work.
Woodworking CAM Software — Frequently Asked Questions
Common questions from woodworking shops and CNC router operators evaluating BobCAD-CAM as their woodworking CAM software solution.
What is woodworking CAM software?
Woodworking CAM software is a CNC programming application that generates toolpaths for CNC routers and machining centers used in wood cutting, carving, and sign making. It takes 2D or 3D geometry and produces G-code that tells the router where to move, at what speed, and with what tool. BobCAD-CAM is BobCAD-CAM combines design, toolpath programming, simulation, and post processing in one system — so shops can go from drawing to cutting without switching applications.
Can BobCAD-CAM woodworking CAM software handle artistic and sign work?
Yes. BobCAD-CAM includes BobART — an artistic module that converts images, logos, and clipart into machinable vectors or 3D relief geometry. Sign shops and decorative woodworking studios use BobART to take customer artwork from file to cut-ready toolpath without needing a separate art CAM or design tool. It supports image-to-DXF vectorization, 3D relief carving, and embossing workflows that produce high-quality results on standard CNC routers.
Does BobCAD-CAM woodworking CAM software support my CNC router controller?
BobCAD-CAM includes post processor support for a wide range of CNC router controllers and brands. If your specific machine configuration isn’t covered out of the box, U.S.-based BobCAD-CAM technicians can help configure or customize a post processor — ensuring your woodworking CAM software outputs clean G-code formatted for your controller’s feed, speed, and spindle conventions. Real phone and remote session support is included.
What’s the difference between 2D routing and 3D carving in woodworking CAM software?
In 2D routing, the cutting tool moves in the X and Y axes with fixed Z depths — ideal for profiles, pockets, slots, and drilling patterns used in cabinet and furniture production. 3D carving adds continuous Z-axis variation to create contoured surfaces, relief carvings, and shaped features. BobCAD-CAM woodworking CAM software supports both approaches within the same system, letting shops handle flat production work and complex artistic pieces without switching software.
How does BobCAD-CAM woodworking CAM software compare to Vectric or Aspire?
Vectric and Aspire are entry-level woodworking CAM tools with a focus on artistic work. BobCAD-CAM delivers a broader CAD-CAM platform that handles woodworking alongside milling, turning, and multi-axis machining — making it a better fit for shops that need one system to cover production routing, sign work, and more complex CNC applications. BobCAD-CAM also provides direct U.S.-based technician support rather than community-only help resources.
Can I use BobCAD-CAM woodworking CAM software for 4-axis router projects?
Yes. BobCAD-CAM woodworking CAM software supports 4-axis routing setups in addition to standard 3-axis CNC routers. Shops that work with rotary fixtures, cylindrical carving, or 4th-axis indexing can use BobCAD-CAM to program those operations within the same CAD-CAM environment they use for everyday flat cutting. See our 4th Axis CAM Software page for more on rotary and 4-axis programming.
