The Milling Job
This topic will describe the Milling Job, where it can be created from, its component items as they appear in the CAM Tree, and the items accessible through its context menu. This topic will also provide links to related topics.
The Milling Job
The Milling Job in the CAM Tree provides the tools needed to define job settings, machine and post processor selection, tools, stock, stock material, and Milling features. It is also used to create index systems, wrapping groups, and toolpath patterns.
To create a Milling Job, use one of the following options:
You can also click to select the Start Stock Wizardcheck box to open the Stock Wizard and define the stock and machine setup for the job once (OK) is clicked.
Milling Job      >>
Default Template
Machine
Post Processor
Milling Tools      >>
Workpiece
Stock      >>
Stock Material
Machine Setup      >>
Fixture
Note: All of the job items in the tree contain a context menu which can be accessed with a right-click.
The Shortcut Menus
Job Settings, Commands, and Setup Sheets
Right-click Milling Job to open a context menu with the following commands.
Milling Job      >>
Note: Templates that control the look of the Setup Sheets are found in the \\BobCAD-CAM Data\**Current Version**\Setup Sheets\Templates folder. Additional templates can be created here by copying and pasting an existing folder and renaming it. These new templates are then shown in the list of selectable templates when creating the setup sheet. The data for the setup sheet is generated as an .xml in this main folder but requires the .xsl and .css files found in the \\BobCAD-CAM Data\**Current Version**\Setup Sheets\Templates\**Selected Template**\stylesheets folder. Users familiar with .css can edit these files to change everything from fonts, formatting, background colors and more of the particular template! Be advised the styling is only supported for Internet Explorer, Edge, Chrome, and Firefox browsers.
Tip: When the Setup Sheet information displays, you can use the File - Save As command of the browser to save the file to another format or for later use. You can also print the setup sheet using the File - Print commands of the browser.
To learn more about the flyouts (      >>) seen in the job, see the CAM Flyouts topic.
The Operation Tree
The Tool Tree
Click here to go to the Machine Selection topic.
