Post Processors
The Post Processor controls the output of your NC programs (G-code), based on the type of machine that will run the program. The layout and format of each post processor is defined in a text file that is stored in the BobCAD-CAM Data folder. The information that is stored in the post processor is used to translate the job information and output it to an .nc file (other extensions are also supported and can be changed in the Current Settings dialog box). Post processor files must use a .BCPst. extension.
Using Post Processors - Use the link to access the dedicated post processor help system to find information and resources related to editing and creating post processors for the BobCAD-CAM software products.
How to Set the Post Processor
It is important that you first define all of the machines that you use and assign a post processor for each machine using the Current Settings Default dialog box. When you create a new CAM Job, the post processor is automatically set using the machine that you select. The machine and the post processor can be modified for the current job using the Current Setting Job dialog box. To learn how to define your machine and post processor, view the Machine Configuration topic.
After defining the machine and post processor in Current Settings, you can use the Post Processor in the CAM Tree to quick-change the post processor for the job. This method should only be used if you have more than one post processor that you use for a single machine. Otherwise, you should select the desired machine to automatically update the post processor for the current job.
Editing Post Processors
To edit a Post Processor:
Post Variable and API Reference
The Operation Tree
The Tool Tree
RS-232 Communications Checklist
