The Tool Crib
This topic will explain the Tool Crib, the options found in it, will describe how to access it, and will provide links to related topics.
The Tool Crib
The Tool Crib is comparable to the tool changer on a machine. It adds two advantages to the CAM system. First, the Tool Crib can be loaded and saved before you create machining features. When the feature operations are created, the system automatically selects the appropriate tool from the Tool Crib. Second, when selecting tools for feature operations, the tool crib shows all tools that are currently defined. By having the tools already defined, you can eliminate the need to search the Tool Library.
In order to load tools into the Tool Crib before creating features, you must create the tools in the Tool Library.
Tip: To learn about all the functionality available in the Tool Library, see the Tool Library Functionality topic.
When tools are created in the Tool dialog box of a CAM wizard that are not pre-loaded into the Tool Crib, they are automatically added.
The left side of the dialog box contains the All Tools list and the tools are grouped by Tool Category: Drill, Mill, Lathe, Laser, Plasma, or Waterjet. When a tool is selected from a tool category on the left, all pre-loaded tools for that tool type are displayed in the Tool Parameters list on the right side. You can also click All Tools.
Note: When the Tool Crib is accessed by clicking Tool Crib from a CAM Wizard Tool dialog box, the list automatically shows only the available tools for that operation type.
To access the Tool Crib, do one of the following:
Use this method to view all the tools currently loaded in the Tool Crib.
Note: This method lists only the tools that are available for the selected operation type. For example, clicking Tool Crib from a Profile operation the Tool page lists end mills, and not threading tools.
The Dialog Box Parameters
When using the Tool Crib, select a category on the left side of the dialog box, and then select a tool type under that category. You can also click All Tools. The available tools are displayed in the Tool Parameters list on the right side. The Tool Parameters list shows the parameters of each tool as defined in the Tool Library.
Tool Parameters
The Operation Tree
The Tool Tree
The CAM Overview
The Tool Library
The Mill Turn Tool Crib
The Tool Library Functionality
