Backplot Visibility (Mill & Lathe)
Backplot Visibility
The new visibility options in Backplot allow you to hide the individual components of the tool! In the past you could control the transparency of the entire tool assembly, but not the individual components. In this release, you can decide which aspects of the tool are visible.
Also as an added note, this same functionality is available when backplotting for lathe operations as well!
Need Additional Help?
Was this article helpful?
