BobCAD-CAM Installer Dependencies
Below is a list of Installer Dependencies which are required to be installed on your computer in order for the software function properly. These should be installed along with the software upon your initial install.
If not, you can find the downloads for the C++ Redistriutables here: https://support.microsoft.com/ and a list of .NET downloads here: https://dotnet.microsoft.com/download/dotnet-framework
BobCAD-CAM V32 - V38
Product Dependency Version Confirmed Install
BobCAD Redistributable  2015-2022 x64 - 14.31.31103 YES Yes
BobCAD .NET  4.7.2 Yes Yes
BobCAD Posting Engine Redistributable 2010 x86 – 10.0.30319 YES – Will not post without it
NC Editor Redistributable  2015 x64 – 14.0.24123 We will not install 2015 since 2017 redist is an update to 2015 and will overwrite No
NC Editor .NET  4.5.2 Yes
SolidWorks swdocumentmgr 2019 Redistributable  2015 x64 – 14.0.24123 We will not install 2015 since 2017 redist is an update to 2015 and will overwrite No
ODBC Database driver?? Redistributable  2010 x64 - 10.0.30319
2010 x86
Yes
PStill  2008 x64
Leadtools  2010 x64 - 10.0.30319 Yes
Stingray  Static built to match BobCAD na
OpenDWG  Static built to match BobCAD na
BobCAD-CAM V31
BobCAD Redistributable 2010 x64 – 10.0.30319 YES Yes
BobCAD .NET 4.0 No
NC Editor Redistributable 2015 x64 – 14.0.24123 Yes
SolidWorks swdocumentmgr 2019 Redistributable 2015 x64 – 14.0.24123 Yes
2010 x86
Yes
PStill 2008 x64
BobCAM for SolidWorks V7 - V13 And BobCAM for Rhino V1, V2, V3
Product Dependency Version Install
BobCAM Redistributable                2015-2022 x64 - 14.31.31103 Yes
BobCAM .NET 4.0 No
NC Editor Redistributable 2015 x64 Yes
PStill Redistributable 2008 x64 Yes
Leadtools Redistributable 2010 x64 Yes
Stingray Static built to match BobCAM na
