📘 BobCAD-CAM Keyboard Shortcuts
Download the PDF here: BobCAD-CAM Keyboard Shortcuts.pdf
The following table lists the default keyboard shortcuts available in BobCAD-CAM:
| Command | Shortcut(s) |
| View – Top | Ctrl + 1 |
| View – Front | Ctrl + 2 |
| View – Back | Ctrl + 3 |
| View – Bottom | Ctrl + 4 |
| View – Right | Ctrl + 5 |
| View – Left | Ctrl + 6 |
| View – ISO 2 | Ctrl + 7 |
| View – Normal | Ctrl + 8 |
| File – New | Ctrl + N |
| File – Open | Ctrl + O |
| File – Save | Ctrl + S |
| Copy | Ctrl + C, Ctrl + Insert |
| Cut | Ctrl + X, Shift + Delete |
| Paste | Ctrl + V, Shift + Insert |
| Undo | Ctrl + Z, Alt + Backspace |
| Redo | Ctrl + Y |
| Select All | Ctrl + A |
| Select Clear | Ctrl + Shift + A |
| Select Mode | Ctrl + D |
| Layer – New | Ctrl + Shift + N |
| Measure – One | Ctrl + M |
| NC Editor | Ctrl + E |
| Job Post | Ctrl + P |
| Lua Plugin Reload | Ctrl + R |
| Cancel | Ctrl + Alt + C |
| Help Topics | F1, Shift + F1 |
⚡ Tip: You can customize these shortcuts in the BobCAD-CAM settings if needed. Just go to File > Settings > System > Customize Shortcuts, add your new shortcuts and hit, "Apply".
