Functionality of Probing
The new probing features offered in our CAM Software includes 41 different probing cycles. By touching off your tools, setting your work offsets, and performing in-process measurements, programming for your probing cycles has never been easier.
There are many in-process measurements cycles including:
- Single surface in X, Y, or Z
- Web to measure the width/length of a part
- Pocket to measure the width/length of a pocket
- Bore to measure the diameter of holes
- Boss to measure circular parts
- Internal/External corners
- 5-Point rectangle internal/external to measure length and width
- Angled surfaces
