Updating a Post for MDI
Break
Beginning with our BobCAM for SolidWorks V10, BobCAD-CAM V35, and BobCAM for Rhino V3 product releases, the MDI feature is now available in Mill and Lathe operations. Previously, this functionality was only available in operations within Mill Turn jobs. To utilize the MDI functionality inside the Mill or Lathe jobs, some simple updates to the post processors are required. This topic will show you how to update the post, and demonstrate generic output.
Default Tasks
With our MDI functionality, the software defaults to having 3 tasks in the Task List of the MDI page available for usage for standard items:
  • Before Tool Change
  • After Tool Change
  • After Operation
Important: Please remember that tasks can have any name and will correlate to a posting variable that is prefixed with MDI_<TaskName>. The variable in the post should have the spaces removed and match exactly to the task name to be output.
Using our default 3 task names, we will explain how to update the post.
Note: As this is a very dynamic functionality, the location of these variables in the post is quite flexible. To explain the overall intention of the design, this example will demonstrate basic placement in the BC_3x_Mill.BCPst. When beginning a file to walk along with this example, ensure you have the same BC_3x_Mill.BCPst file selected in the CAM Tree.
Steps
Break
Step 1) Update the Tool Change / Start Blocks
In this first step, we add the MDI_BeforeToolChange and MDI_AfterToolChange variables in the following blocks:
  • Mill
    • 2. Start of file standard
    • 3. Tool Change
    • 4. Null Tool Change
    • Not in probe tool changes due to no MDI in probing
  • Break
  • Lathe
    • 1002. Start of program with turning cycles
    • 1003. Tool change for turning
    • 1004. Next operation same tool turning
  1. Navigate to your C:\BobCAD-CAM Data\**Current Version**\Posts\Mill folder and open BC_3x_Mill.BCPst in your preferred text editor.
    Break
  2. Scroll to block 2.
    Break2. Start of file standard        n,rapid_move_forced, work_plane, force_cancel_offset,"G49",work_coord,cancel_drill_cycle,measure_mode,absolute_coord        " "        "(FIRST CUT - FIRST TOOL)"        system_comment        feature_name_comment        " "        "(TOOL #",list_tool_number," ",tool_diameter," ",tool_label,")"        n,t,"M06"        n,work_coord        output_primary_rotary_index        output_secondary_rotary_index        n,rapid_move,absolute_coord,xr,yr,p_rot,s_rot,s,spindle_on        n,rapid_move,length_offset,d_offset,zr,coolant_on
    Where we place the variables for the tasks is where the lines and commands we add to those tasks will appear in the code. This is where we can see some of the flexibility available to us. Break
  3. In this case we will assume we want the lines we specify in the MDI_BeforeToolChange variable to be called before our tool, and before the tool label we output in parentheses.
    Break Add MDI_BeforeToolChange just above our list_tool_number line.2. Start of file standard        n,rapid_move_forced, work_plane, force_cancel_offset,"G49",work_coord,cancel_drill_cycle,measure_mode,absolute_coord        " "        "(FIRST CUT - FIRST TOOL)"        system_comment        feature_name_comment        " "        MDI_BeforeToolChange        "(TOOL #",list_tool_number," ",tool_diameter," ",tool_label,")"        n,t,"M06"        n,work_coord        output_primary_rotary_index        output_secondary_rotary_index        n,rapid_move,absolute_coord,xr,yr,p_rot,s_rot,s,spindle_on        n,rapid_move,length_offset,d_offset,zr,coolant_on Break
  4. For our MDI_AfterToolChange variable, we may want to allow our work coordinates and rotary calls to be output prior to any additions we call after the tool change.
    Break Add MDI_AfterToolChange just after the output_secondary_rotary_index line.2. Start of file standard        n,rapid_move_forced, work_plane, force_cancel_offset,"G49",work_coord,cancel_drill_cycle,measure_mode,absolute_coord        " "        "(FIRST CUT - FIRST TOOL)"        system_comment        feature_name_comment        " "        MDI_BeforeToolChange        "(TOOL #",list_tool_number," ",tool_diameter," ",tool_label,")"        n,t,"M06"        n,work_coord        output_primary_rotary_index        output_secondary_rotary_index        MDI_AfterToolChange        n,rapid_move,absolute_coord,xr,yr,p_rot,s_rot,s,spindle_on        n,rapid_move,length_offset,d_offset,zr,coolant_on Break
  5. Repeat this process for block 3. Tool Change.
    Break
  6. We repeat this for block 4. Null tool change as well, but in this case we place MDI_BeforeToolChange after the blank line after feature_name_comment, and before the work_coord line.
    Break4. Null tool change        " "        "(NEXT CUT - SAME TOOL)"        system_comment        feature_name_comment        " "        MDI_BeforeToolChange        n,work_coord        output_primary_rotary_index        output_secondary_rotary_index        MDI_AfterToolChange        n,rapid_move,absolute_coord,xr,yr,p_rot,s_rot,s,spindle_on        n,rapid_move,length_offset,d_offset,zr,coolant_on Break
  7. Press Ctrl+S to save the changes to the post.
Note: The MDI_BeforeToolChange variable would be added in all the above blocks that are called at the beginning of an operation where the tool information is output (either a change to a new tool or using the same tool in the next operation).
Note: The MDI_AfterToolChange variable would be added in the same blocks, after the tool has been changed but prior to the initial position of the toolpath. You will see in the example below, we have chosen to place any of the lines of code that are added from the MDI after the rotary axes have been positioned, but prior to moving to the initial position of the toolpath.
Break
Step 2) Update the End of Operation Blocks
Next, we add the MDI_AfterOperation variables to the following blocks:
  • Mill
    • 197. End of operation – Toolchange
    • 198. End of operation - No Toolchange
    • 199. End of last operation
  • Break
  • Lathe
    • 1197. End of operation – Toolchange
    • 1198. End of operation – No Toolchange
    • 1199. End of last operation
  1. Scroll to block 197.
Break 197. End of operation - Toolchange        n,coolant_off        n,spindle_off        n,optional_stop Break
  • Add the variable MDI_AfterOperation as the last line.
Break
197. End of operation - Toolchange        n,coolant_off        n,spindle_off        n,optional_stop        MDI_AfterOperation Break
  • Scroll to block 198.
Break
198. End of operation - No Toolchange Break
  • Add the variable MDI_AfterOperation.
Break
198. End of operation - No Toolchange        MDI_AfterOperation Break
  • Repeat this for block 199. End of last operation.
    Break
  • Press Ctrl+S to save the changes to the post.
Break
Note: The MDI_AfterOperation variable should be added to the above blocks, typically, as the very last line of this block. Then any lines of commands added in MDI in the After Operation task will happen after the operation has completed, prior to anything being output for the next operation.
Break
Step 3) Add the 2600-2699 Comment for Future Reference
The 2600-2699 blocks of the posts are the reserved blocks for Custom MDI Commands which allow users and post writers to create custom commands which will be visible within the MDI operation dialog. These blocks can be used two ways:
  • Direct output from adding the command.
  • Usage of:
    • mdi_custom_int_ParamName : allows for output of an integer value.
    • mdi_custom_double_ParamName : allows for output of values with decimals.
    • mdi_custom_string_ParamName : allows for output of alphanumeric characters.
Part 1) Updating the Post
  1. Create a line in the graphics area so we have something to apply toolpath to.
    Break
  2. Create a Mill 2 Axis feature.
Break The Mill 2 Axis Wizard appears. Break
  • Select the line as the geometry for the feature.
    Break
  • Move to the MDI page and notice the Custom Commands in the Commands list.
Break
Break
We can see there are currently no Custom Commands. Break
  • Click Finish to exit the Mill 2 Axis Wizard.
    Break
  • Open the post processor and move to the end of the post, and add:
Break
//--------------------------------------------------------------------- // 2600-2699 - Reserved for Custom MDI Blocks //---------------------------------------------------------------------
This is simply a note for ourselves to remember the blocks available for custom mdi block which should not be used for anything else. Break
  • Skip one line and add 2600..
Break
2600. Testing
This adds an item to the Custom Commands. Break
  • Move down a line and add:
Break
2600. Testing        " ",mdi_custom_int_Integer        n," ",mdi_custom_double_Decimal        n," ",mdi_custom_string_AlphaNum
This adds each of the variables with names to correspond to their use: Integer, Decimal, and AlphaNum. This also separates them by lines. Notice that while the first does not begin with an "n", the others do. A line number is automatically added for our 2600 block item, but the other lines we created will not have a line number without the "n". We also add the quotes with a space to create a space between the line number and the output of our variables. Break
Break
2600. Testing        " ",mdi_custom_int_Integer        n," " ,mdi_custom_double_Decimal        n," ",mdi_custom_string_AlphaNum
2601. Testing B        "D",mdi_custom_int_Int-D,"E",mdi_custom_double_Dec-E,"F"mdi_custom_string_AN-G
This adds each of the variables with names to correspond to their use: Int-D, Dec-E, and AN-G. In this case they are placed on the same line with a prefix in quotes placed before each.
Part 2) Testing the Resulting UI
  1. In the CAM Tree, under the selected machine, double-click BC_3x_Mill.BCPst to open the Set Post Processor dialog.
Break The Set Post Processor dialog appears.
Tip: If the double-click did not open the Set Post Processor dialog, this behavior can be updated in the Tree Behavior group found on the System>User Interface page of the Settings dialog. Set Double-click to Edit rather than Expand/Collapse.
  1. Click OK.
Break Doing this reassociates the post processor in order to use the updates we just implemented. Break
  • In the CAM Tree, double-click our Feature 2 Axis.
Break
  • Move to the MDI page and notice Custom Commands can now be expanded.
Break
Expand Custom Commands. Break
Part 3) Inserting Commands
Break
  1. With Before Tool Change highlighted in the Task List, click our 2600. Testing command, and click   Add Command.
Break
Break
The Before Tool Change task expands. Break
  • In the Parameters group, update the values to:
Break
  1. Integer : 1
  2. Decimal : 2.3
  3. AlphNum : Four
Break
  • Highlight the 2601. Testing B command, click After Operation, then click   Add Command.
    Break
    Break
    The After Operation task expands. Break
    1. Int-D : 5
    2. Dec-E : 6.7
    3. AN-G : 8(eight)
  • Break
  • Click Finish to exit the wizard.
Part 4) Posting the Code
  1. In the CAM Tree, right-click Milling Job and select Post.
BreakThe code is posted.          N02 1          N03 2.3          N04 Four          (TOOL #1 0.5 1/2 FLAT ROUGH ENDMILL - STANDARD)          N05 T1 M06          N06 G54          N07 G90 X0. Y0.265 S595 M03          N08 G43 H1 D1 Z3. M08          N09 Z2.2          N10 Z2.1          N11 G01 Z1.5 F3.3369          N12 X1. F6.6738          N13 G00 Z2.2          N14 Z3.          N15 M09          N16 M05          N17 M01          N18 D5 E6.7 F8(eight)          N19 G90
This concludes the example
