What's New in BobCAM for SolidWorks V13 SP2
The second update to our BobCAM for SolidWorks V13ยฎ includes general corrections, CAM corrections
CAM โ€“ General
BCC-2933 โ€“ Corrected an issue where Phantom operations could appear in the CAM Tree after copy/paste and file reload.
BCC-2897 โ€“ Added an option to change the background color of operations in the Operation Tree based on the index, which the user can turn off.
BCC-2946 โ€“ Corrected an issue where the Group Retracts Axis parameter did not retain the user-selected option in the CAM Wizard.
Mill
BCC-2907 โ€“ Corrected an issue where G99/G98 Hole Group commands were not output correctly.
BCC-2934 โ€“ Corrected an issue where Deburring operations did not compute a toolpath in BobCAM for SolidWorks.
BCC-2935 โ€“ Corrected an issue where a Lead-out would default to Vertical when โ€œSame as Lead-inโ€ was not checked.
BCC-2941 โ€“ Corrected an issue where a selected Hole Recognition hole group no longer highlighted the geometry in the CAD window.
5-Axis Milling
BCC-2908 โ€“ Corrected an issue where indexed 5-Axis operations did not adhere to the limits set in MachSim.
Lathe
BCC-2883 โ€“ Corrected an issue where the Trim to Stock option did not work when creating a new Turn (Rough) feature.
BCC-2931 โ€“ Corrected an issue where Thread Per Unit was not tied to the Feedrate in a Lathe Thread operation.
BCC-2940 โ€“ Corrected an issue where Cutter Compensation (G41/G42) was not output in Canned Cycles.
BCC-2963 โ€“ Corrected an issue where Apply to All did not work on the Lathe Rapids and Leads page.
BCC-2965 โ€“ Corrected an issue where RPM mode was chosen even though the tool had Feeds and Speeds saved as CSS.
BCC-2970 โ€“ Corrected an issue where a Threading cycle posted in the reverse direction on specific geometry.
Mill-Turn
BCC-2881 โ€“ Corrected an issue with the Drilling Spindle Speed in the Mill-Turn/Lathe module.
BCC-2927 โ€“ Corrected an issue that could cause a Y-axis overtravel error.
BCC-2893 โ€“ Corrected an issue where a 2-Axis toolpath displayed broken in Simulation for Mill-Turn.
BCC-2966 โ€“ Corrected an issue where the Tool Offset Register 1 (Diameter) value was not posted in a Mill-Turn Lathe operation.
Wire EDM
BCC-2832 โ€“ Corrected an issue with the sorting of Wire EDM operations in the Operations Tree.
Tooling
BCC-2939 โ€“ Corrected an issue where tools created in the Tool Crib did not retain their assigned number when moved to the Tool Library.
BCC-2969 โ€“ Corrected an issue where tools created in the Tool Library were renumbered when moved to the Tool Crib.
BCC-2903 โ€“ Corrected an issue related to the โ€œAdapterโ€ field in the Mounting Location dialog.
Posting / Toolpath Output
BCC-2894 โ€“ Corrected an issue where Mazak machines required a positive X value before a G12.1 was output.
Customization / Lua API
BCC-2937 โ€“ Corrected an issue where MILL_GetDrillCycleType() returned an incorrect value for a Left-Hand Tap operation.
