CAD-CAM Technology Provides Step Reduction to Improve 3D Roughing
Posted February 19, 2018 5:10 pm   Published by    BobCAD-CAM ">
CAD-CAM software programmers and CNC machinists understand the importance of using advanced technology that provides optimum 3D roughing & finishing operations. Step reduction functionality in CAM can provide a significant advantage, provide improved finishes and even reduce machine cycle times. CAD-CAM is used for programming these complex 3 Axis machine toolpath and optimizing NC programs so that they are shorter, more accurate and provide improved finish results. Step reduction for 3D roughing is the icing on the cake for achieving optimum results.
step reduction in cad-cam
CAD-CAM Software Advanced Roughing and Step Reduction
One of the challenges that CNC shops face when it comes to 3 Axis milling is in the area of complex roughing or “Z-Level” roughing. This is also known as “waterline” or “Core milling” in the world of CAD-CAM software part programming. When leaving the world of 2D milling and entering the world of complex 3D surface machining, a new set of particular skills are required for generating an accurate and efficient NC program. Without CAD-CAM software, these types of CNC jobs can be nearly impossible to cut due to the math calculations involved. Fortunately, modern CNC software products provide a variety of 3D machining capabilities that continue to give programmers faster, smarter and easier solutions to machining difficult 3D parts. Z-Level Roughing operations are generally used as a way to remove the majority of the material necessary to perform a semi-finish roughing operation with a smaller tool that has a reduced step over and Z step-down during cutting. The advent of “Step Reduction” technology brings a faster and far more efficient method of machining that helps speed up cycle times and produces improved part finishes.
Step Reduction Using Intermediate Steps
CAD-CAM step reduction technology is used to reduce the large stair type effect that is created as the roughing tool machines down the part contour at each Z axis cutting level. This large stair step effect makes semi-finishing more difficult and even harder on cutting tools. The solution is to add a secondary action to the process that starts at the bottom of the Z-Level roughing stage and comes back up machining intermediate Z-Levels until the tool has reached the top of the part.
cad-cam step reduction cycle
The result is a much better finish before semi-finishing has even taken place. This is considered one machining strategy and doesn’t require a tool change. The intermediate steps are controlled by the user and can be as many as required to achieve the required results.
5 Ways CAD-CAM Software Improves Advanced 3D Roughing
CAD-CAM software developed to support duel-core processors calculating toolpath in minutesCAD-CAM software developed to support duel-core processors. Multi-threaded toolpaths are important as calculation times are hugely reduced when the CAD/CAM software supports hardware with duel-core processors. It could mean the difference of clicking the “calculate” button and going home for the day versus clicking the calculate button and having your toolpath calculate within minutes.
cad-cam-pointCAD/CAM software that provides roughing “Step-Reduction” functionality. 3 Axis roughing operations can leave a large stair-step type finish after machining that will require a second machining operation to reduce the left over material before finishing. Using CAD/CAM that offers functionality for “Intermediate Steps” or added forced steps in cutting is important. Equally important is the transition from one tool and step over to another along with the characteristics of how such a machining operating operation performs. Creating an efficient program is the main objective. It isn’t always necessary to perform a tool change from one set of cut-paths to another.
Step Reduction functionality allows you to machine material from top down then back up
Step reduction functionality allows you to machine the bulk of material from the top down and then machine back up the walls of the part removing the remaining material in specified equal intervals. You could call this, “Automatic Step reduction.” The benefit is efficiency, whereas this type of functionality makes the most out of the program and reduces the amount of finishing time while supporting tool life.
cad-cam-pointCAD/CAM that provides High Speed Advanced Roughing. Traditional Z-Level roughing toolpaths can be hard on tools and even though advanced step-reduction functionality may exist, high speed machining technology can consolidate the benefits of step reduction while greatly reducing machine cycle times. Not to mention that high speed toolpath benefits also include extending tool life due to a constant cutting engagement and increased cutter step-over advantages. Basically, using more of the tool at higher cutting speeds. The nature of this toolpath is to use more circular machining movements rather than traditional right and left turn movements. BobCAD-CAM software is currently the only CAD/CAM product in the world that offers this level of advanced Adaptive High Speed roughing technology for 2, 3, 4 and full 5 Axis CNC Milling.
High speed S-Link toolpath found in BobCAD-CAM's CAM softwareAdvanced roughing toolpath operations for complex parts should also include toolpath “Linking” options. This is the methods that a tool will take when moving from one toolpath to another. Your part may require a retract from one cut to another, a direct move from one toolpath to another or a “S” type high speed link from one cut to the next. The S-Link creates an S shape link between each path in the toolpath tangent to both paths that lie on the surface of the model.
cad-cam-pointCAD/CAM that provides REST operations. Advanced roughing operations will leave material behind where the larger tool could not machine. CAD/CAM software should allow you to take the previous tool data and generate toolpath for the next smaller cutter based off of the previous operation and allow you to machine the rest. This operation will save you time due to the pure automation value and recognizing leftover material that needs machining.
Rest Milling
cad-cam-pointCAD-CAM that optimizes the toolpath and uses ARC segments wherever possible rather than line segments. Generally toolpath in CAM is created using tiny line segments that will result in individual lines of g-code in the output program. When possible you may want to use arc segments through a feature called, “ARC Fit” that will use arcs instead of lines for the toolpath. This has value in the cleanliness of the machine path as well as the size of the g-code program that your machine will need.
cad-cam-arc-fit-posting-options
By using this option you can greatly reduce the size of the program and produce improved toolpath results. These are some of the attributes you should review when implementing CAD-CAM software into your business for 3D machining. Each of them adds efficiency to offline program and gets you one step closer to better parts finished faster.
How Advanced Roughing Step Reduction Works in BobCAD-CAM
CAM software should provide the operator with a Job Tree Manager which is the central command of creating toolpath and NC programs. The Job Tree is where you will perform job setup tasks, select tools, materials, create the stock and access all of the machine operations that the program would offer. BobCAD-CAM software offers this type of scenario where a Job Tree is used for all of the above including post processing configurations, cutting conditions, machine setup options, indexing operations and more.
CAD CAM software's Advanced Roughing and Dynamic Machining StrategiesIn the BobCAD-CAM software the operator will start a new job, define the stock through a “stock wizard” and then chose the 3 Axis Mill strategy for the job from the CAM tree.
A Machining Wizard is a series of dialog boxes that step an operator through all actions/stages associated with a machining operation. This is a huge benefit to new users as they literally remove the guesswork from programming. Advanced users also appreciate the wizards as they provide a large amount of flexibility in creating a program as there are a lot of options and override opportunities that make experienced users feel totally in control. In the case of BobCAD-CAM software, machining wizards are used for all machining operations to provide ease of use in addition to the Dynamic Machining Strategies™ that are included. DMS™ functionality allows the operator to apply as many 3 Axis machining operations as needed to a single CAD feature of the model. This populates a job tree that is inside the wizard which saves a lot of programming time, mouse clicks and moves.
NOTE: Use CAD-CAM software that provides machining wizards. This makes programming easy and steps you through the process removing any guesswork.
The stages of the advanced roughing wizard include:
– Rapid Movement Settings. These input fields will include the Clearance Plane, Rapid plane, Feed Plane and the Top of Part.
– Posting options. Most CAD-CAM software will allow the operator to add an index system to the job for 4th axis indexing. The index system will allow the operator to include machining operations. If this is the case, the wizard allows the operator to input the output rotary angle for the selected machining operation. This stage of the wizard should also offer the ability to use an ARC Fit option. This is where the operator can input an arc tolerance value which will be used when the software uses arc segments wherever it can in the toolpath. Once again, this will improve the quality of the toolpath and reduce the number of lines of g-code.
– Tool Data. The next phase of the wizard will give the operator access to the tool library, tool crib library, tool holders, feed and speed setting and override options as well as height and diameter offset fields and coolant options for the tool being used. The CAM software will automatically supply tool speeds and feeds based off of the material, operation and the size and type of tool that is being used. The selected operation will dictate the tools that are automatically inserted into the program. However the operator always has full controll over the tools that will be used in creating the program.
– Machining Patterns and Cutting Direction. Depending on the operation there will be styles of machining patterns that can be used. In BobCAD-CAM Mill PRO software the Advanced Roughing strategy offers three different patterns, one of which is the new high speed adaptive roughing. Climb & conventional milling options are available as well.
– Parameter Settings. BobCAD-CAM provides the operator with Depth and Step Over options. This includes an “Intermediate Steps” option and the number of intermediate steps the user wishes to use.
This is the phase of the wizard that gives you “step-reduction” benefits. The operator simply inputs the number of intermediate steps which creates forced cuts at even depths. In addition to this, another unique option is the ability to define what the top and bottom of the job will be. This allows the operator to control machining within the Z axis of the part.
CAM software Job Wizard
These options and others give the operator solutions to machining in a variety of scenarios while providing total control.
CAD-CAM Wizard Ramping Options– Leads. There has to be options for the tool leads. Common options are Plunge, center cutting tool and Ramping options. Along with Ramping will be settings that should provide further control for using a linear ramp, spiral ramp, zig-zag style or a profile type ramp option. The lengths of ramp type and angle of approach is also important depending on the style of ramping that is chosen.
Special options for REST machining, Flatlands machining and how the operator would like to process the part for depth and region machining (By area or By level) among other options. Depending on the step-over and tool diameter there can sometimes be pegs left standing in corner areas where the toolpath takes a left or right turn. Among special options is the setting to remove these potential pegs by extending the toolpath slightly outward and back inward in these corners. It’s these types of options that can be useful when using advanced roughing toolpaths.
Toolpath linking options. Toolpath that is for machining along the part at the same Z level has links between cuts. Direct, s-links or a retract type link can be used depending on the part and how the operator wishes to output the toolpath and program.
Once the operator has completed the process of setting up the operation with the wizard they would simply click a “Compute” button and the software would automatically create the toolpath and load everything into the CAM Job Tree.
The advanced roughing toolpath would first machine everything from the top down based off of the input parameters and then start back upward from the bottom performing the intermediate cuts along the outer walls of the surface or cavety, reducing the large stair type effect that normal roughing can cause and leaving behind a much smoother and easier surface for the finishing toolpath to machine.
Advanced CAD-CAM Simulation & Deviation Analysis
A CAD-CAM system should have simulation capabilities so that the operator can visually inspect the operations. Complex part programs will most likely have several machining strategies that makes the job. Each of these can be analyzed through simulation including a part deviation analysis, machine cycle time calculation and much more.
CAM software Simulation process Roughing and Finishing Simulation
CAD-CAM advanced roughing with intermediate steps is an important machining operation to use when programming complex 3D parts. It can be a huge time saver with a lot of different programming benefits.
NOTE: All of the CAD-CAM functionality written about in this article is available as functionality in BobCAD-CAM CNC Software. The advanced roughing, REST, High Speed Adaptive Roughing and advanced Machine Simulation are available in the Mill 3 Axis PRO version of the software.
For more information on CAD-CAM software call BobCAD-CAM, Inc. at 877-262-2231 or 727-442-3554.
Try a Free CAD-CAM demo Today! Click HERE
Other CAD-CAM related links you may be interested in:
7-steps-to-better-cad-cam-software-productivity top-10-cad-cam-advantages-for-cnc-machining
