Product Matrix
BobCAD-CAM Product Matrix
CAD/CAM Software Features
Expand All | Hide All
CAM Features (click to expand)
Machining Features V21 V25 V25 Pro BobCAM BobCAM Pro
User Defined Custom Lathe Tools
RS-232 Communication
RS 232 DNC
Independent Lead In Lead Out Controls
Pocket Ramping
3D Linking and Lead Control
Tool Database
Material Based Calculated Feeds and Speeds for Mill
Ability to Save and Load Features
Individual and Compound Drilling Operations
Associative CAM
3D Simulation for Mill and Lathe
Stock Wizard
Machine Setup
Tool Crib
Machine Definitions
Material Speed & Feed Library
Tool Holder Library
Boundary Selection Options
Advanced Roughing / Adaptive Toolpath
3 Axis Machine Tolerance Option
Facing for Irregular Shapes
Advanced Roughing Flatlands Operation
Hole Recognition
Depth Recognition
Pocket Recognition
Mill & Router Tool Paths (click to expand)
Drilling
Peck Drilling
Tapping
Ream
Counter Bore
2.5 Axis Profiling
2.5 Axis Pocketing
2.5 Axis Facing
2.5 & 3 Axis Engraving
2.5 Axis Chamfer
3D Slice Planer
3D Slice Spiral
3D Engraving
4 Axis Indexing Add-On Add-On
4 Axis Rotary Conversion Add-On Add-On
3D Slice Radial
2D & 3D Plunge Roughing
3D Z-Level Roughing
3D Z-Level Finishing
2.5 & 3 Axis Threading
3D Advanced Roughing & Rest Machining
3D Adaptive Roughing
3D Pencil
3D Flatlands
EquiDistant Offset Contour
Posting Features (click to expand)
Fanuc Style Canned Cycle Support
Profile Cutter Compensation G41 & G42
Work Offset Selection
Coolant Selection
Sub Program Output
3D Arc Fit – G17, G18 & G19 Plane Cutting
Associative CAM Tree
Laser, Plasma and Waterjet Toolpath (click to expand)
Profile Cutting
Cutter Compensation
Lathe Tool Paths (click to expand)
OD Profile Roughing
OD Profile Finishing
ID Profile Roughing
ID Profile Finishing
Grooving Cycle
Threading Cycle
Cut Off Cycle
Stock Feed Cycle
Custom Functionality and Dialogs – (Additional Cost) (click to expand)
Custom Cutting Conditions Database for Posting
Multi-Head Support
Additional Axis Indexing
Custom CAM Dialogs with Custom Functionality
Surface Creation & Tools (click to expand)
Planar
Skin
Revolve
Offset
3 Edge
4 Edge
Cross Section
Extrude Curve
Extrude Surface
Multi-Sided Patch
Fillet
Extend Surface
Intersection Curves
Un-Trim Surface
Break Surface
Solid Creation & Editing (click to expand)
Sphere
Cube
Cone
Cylinder
Torus
Fillet
Add, Subtract and Intersect Booleans
Sweep
Text (click to expand)
Center Line Fonts Included
Windows TTF (True Type Font) Files Can Be Used
Fit Text to Curve
Text Vectorization (Explode)
Dimensions (click to expand)
Standard Dimensioning
Dimension Preferences
Point Dimensioning
General CAD (click to expand)
Points Lines, Arcs & Splines
Snap Point Placement
Coordinate Placement
Deform and Drag
Incremental & Absolute Coordinate Input
Continuous Sketch Arcs
UCS & Layer Control
Select by Color
Select by Layer
Selection Filters
Rotate, Translate & Copy
Many Trim & Extend Features
3D Surface Edge Extraction
Stitch and Un-Stitch Surfaces
Project Curves to Surfaces
Erase Doubles Tool
Mark Arcs Tangential Tool
User Preferences
Multi View Windows
Tangent Lines
Hole Patterns
Roller CAM Generator
Arc Fit
Full Time 3D Render
Quick Trim
Gear & Sprocket Generators
Unwrap
Improved User Coordinate System
View Normal
Stretch
Feature Preview
Spline Modify
*Optional Add-In Required (click to expand)
Multi-Sheet Nesting
Dado Detection Based on Layers
Summary & Leftover reports
Hole Detection Based on Layers
Machining Order Selection
Bridge Distance and Stock Margin Control
Start Point Control for BobCAD Parts
Batch DXF Import
Automatic Tabbing
DXF Sheet Export
Sub Programs with Rotation
3D V-Carving* with BobART Add-In
File Import (click to expand)
CAD – Legacy BobCAD-CAM
DXF – AutoCAD
DWG – AutoCAD
STEP,STP – Step
IGES,IGS – Iges
SAT – ACIS
3DM – Rhino
X_T – Parasolids
X_B – Parasolids
SLDPRT – SolidWorks
BBCD – BobCAD-CAM
STL – Stereo Lithography
File Export (click to expand)
IGES, IGS – Iges
DXF – AutoCAD
DWG – AutoCAD
SAT – ACIS
3DM – Rhino
STP,STEP – Step
BBCD – BobCAD
Protected
2013-05-24 01:28:15
