Open Source Sofware
BobCAD-CAM Version Matrix
GENERALV26V27V28V29
32-bit Application
64-bit Application
BobCAD LIVE
3DConnexion 3D Mouse Support
Zoom to Cursor
Getting Started System
Ability to Hide World Coordinate System from Workspace
MillV26V27V28V29
Stock Wizard
CAM Wizard
Material and Speed & Feed Database
Tool Holder Library
Picking from Solids for 2 Axis Machining Operations
Open Pocketing
Adaptive High Speed Pocketing
Multi Pass Pencil Milling
4 & 5 Axis Indexing / Positioning
4 Axis Rotary Toolpath
4 Axis Wrapping
5 Axis Trimming
3 - 5 Axis Simultaneous Surface Based Toolpath Strategies
5 Axis Roughing
5 Axis Swarf Machining
Multiple Depth 3D Engraving
V-Tool, Lollipop, T-Cutter, and Dove Mill Tools Available for Profiling
Corner Round Tool and Operation
Rest Machining for Pocketing
Equidistant Rest Finishing
Parallel Cut Pattern for Advanced Rough
Improved 2 Axis Lead In/Out Strategies
Advanced Planar Toolpath
Advanced Z Level Finish Toolpath
Project Curves Toolpath
Equidistant with Drive Curves
Intermediate Roughing with Advanced Rough
Trim to Stock for 3 Axis Pro Operations
Enhanced Boundary Control for 3 Axis Pro Operations
Angle Ranges for Steep/Shallow Machining
Resting Finishing for 3 Axis Pro Operations
Multidepth Hole Recognition for Drilling, Tapping, and Threading
Multiaxis Drilling Hole Recognition
Cross Drilling Hole Recognition
Advanced Drilling Retract Options
Custom Revolved Tool Creation
Tabbing for 2 Axis Profiling
Perpendicular Stepover for Advanced Planar
Round Corners for Advanced Planar
Separate Side and Bottom Allowance for 3 Axis Pro Operations
Picking Wrapped Geometry and Viewing 4 Axis Wrapped Toolpath
Trim to Stock for 4 Axis Rotary Toolpath
Revolved Stock Creation for Mill
Tapered Thread Milling
Thread Mill Side Roughing
Machine Compensation Support for Thread Milling
Robust Thread Mill Tool Definitions
Spiral Pocketing for Circles
Helical Arc Output For Spiral Entries
Improved Open Shape Detection for Advanced Pocketing
Gouge Checking
Rest Finishing from STL Stock Model
Advanced Rough - Parallel Cutting - Profile After
Stock Thickness Detection for Rest Machining
Tool Outside, Inside, Center and Offset of Boundaries for Advanced Rough
Parallel and Adaptive Patterns for Flatlands
Advanced Planar Round Corner & Step Down Option
Advanced Z-Level Finish -Machine Vertical Walls Only
Advanced Z-Level Finish - Full Contour Pass Options
Optimized Multiaxis Posting Settings
Extend Edge Curve
Exact Stepover Option for Morph Between 2 Curves
Flowline Toolpath
Mirror Option
Common Direction Tilting Options
Gouge Checking - Retract Tool Along Tool Plane
User Controlled Point Distribution
Maintain Tilt
Backplot
CADV26V27V28V29
CAD Preview
Stretch Function
Spline Modification
Solid Action Tree
Dynamic Drawing and Positioning for 2D and 3D
Shape Library
2D Booleans
Extract Edges - Project to Z
Nonuniform Scaling of Wireframe and Solids
Extrude Boss/Cut
Shelling
Solid Split
Section View
Swung Service
Ruled Surface
Improved Surface Filleting
Snap Increment for Dynamic Drawing
Spun Profile
Chain Filleting
Quick Unit Access from Status Bar
CAMV26V27V28V29
Multi-Threaded 3 Axis Pro Toolpath Calculations
Full Machine Simulation for Milling and Mill Turn
Tool Crib
Multiple Machining Jobs in One File
Copy and Paste of Features and Operations
Dynamic Machining Strategies (DMS)
Setup Sheets for Mill and Lathe
Apply All Functions in CAM for Faster Programming
Picking Depths from Solid Models for Holes
Dynamic Posting Order
New Ribbon Bar User Interface for Simulation
Workpiece Definition
Backplot
Update All Geometry (CAM Tree)
Groups (CAM Tree)
LatheV26V27V28V29
Canned Cycle and Separate Move Support for Most Common Cycles
Roughing
Finishing
Pattern Repeat
Grooving
Part Off / Cut Off
Stock Feed
Threading
CAM Wizards
Stock Wizard
Enhanced Drilling and Tapping
Feature Type & Regions Options
Toolpath Constraints
Geometry Extension
Automatic Removal of Undercuts
Rapid on Entry Options
Rapid Plane Option
End Face Feature
New Tool and Holder Definitions
Backplot
Mill TurnV26V27V28V29
Support for Many of the Most Popular Mill Turn / Live Tooling Machines
Multiple Turret Machine Support
Support for Subspindles
Tool Crib for Easy Mounting of Tools and Adapters
5 Axis Milling Spindle Support
Job Setup Wizard
MDI ( Manual Data Input ) for Motion, Part Transfers, Tailstocks and More
Turret and Tool Adapter Library
New Lathe System
Wire EDMV26V27V28V29
CAM Wizards
Stock Wizard
Material & Cutting Conditions Databases
2 Axis Cutting
4 Axis Cutting
Easy to Use 4 Axis Syncing Options
Wire EDM Cut Simulation
Setup Sheets
Edit Cutting Conditions Libraries
Toolpath Patterning
Enhanced 4 Axis Taper Cutting
Backplot
BobARTV26V27V28V29
Vectorization - Up to 64 Levels of Color
Wrapped Embossed Models
Remove Non-Embossed Area
Emboss from Component and Component Creation
Supress BobART Features
Custom Cross Section
NestingV26V27V28V29
True Shape Nesting
Rectangular Sheet
Part-in-Part Nesting
Part Priority
Auto and Manual Tab Creation
Complete Re-Engineer of Entire Nesting Routine
CAM Wizards for Nesting
Fast vs Optimal Nesting Optimizers
Improved Part Importing from Separate Files
Custom User-Defined Sheet Shapes
Improved Part-in-Part Nesting
Preferential Hole Filling for Part-in-Part
Remnant Sheet Generation
Filler Parts
Sheet Priority and Quantities
Variable Stock Margins for Rectangular Sheets
Grain Direction Handling
Improved Part Tabbing for Laser Plasma and Waterjet
Thermal Consideration in Cutting Sequencing
Local Area Nesting
Improved Nesting Summary Information
