When you select a tool for a feature wizard operation, a specialized version the Tool Library, the Select Tool dialog box, is displayed. The Select Tool dialog box only displays the appropriate tool types based on the operation type.
In the
CAM
Tree, right-click
Milling Tools or
Turning Tools,
and click Tools.
This opens the Tool Library showing only tools for the selected job type (Mill or Lathe).
In the Milling Tool Crib dialog box, click Add From Tool Library.
This method is used to add a tool from the Tool Library to the Tool Crib.
When you open the Tool Library, first expand the desired tool category on the left side of the dialog box. Next, select a tool type that you want to create or modify. You can then use the following options.
Import from File - displays the Open dialog box allowing you to navigate to and load a previously saved Tool Library file (.mtools or .ltools).
Add - opens the Create/Modify Tool dialog box allowing you to create a new tool of the selected Tool Type.
Delete - removes the selected tool.
Modify - opens the Create/Modify Tool dialog box allowing you to change the parameters of the selected tool.
