The Parameters group of the tool crib contains the tool ID and tool numbering settings for mill turn jobs. When you select a tool in the tools list or the device tree, the parameters for that tool become available for editing.
The Use Automatic Tool ID option allows you to automatically or manually set the tool ID. The tool ID is used to set the offset register number for the tool.
On - the software automatically sets the tool
ID based on the machine's tool devices and one other setting: Auto
Tool Numbering By Device. This option determines whether the automatic
tool ID is created for each device separately (the tool ID numbering
starts at one for each tool device) or for all devices of the machine
together (unique ID for every tool).
Off - makes the Tool ID box available so you
can type the tool ID number (manual tool ID).
The tool numbering settings provide three ways for you to generate tool numbers for Mill Turn jobs. Two of the options, Tool ID and Station Number automatically generate the tool number for you based on the selected setting, and the Manual option allows you to type the tool number directly in the tool crib.
IMPORTANT: -1 Tool Number: Mill Turn Jobs use a special convention in the tool crib for tools that are assigned, but have not been mounted. The tool number for an assigned tool that isn't mounted displays as -1 (negative one). You must mount all assigned tools before posting or simulating a Mill Turn program.
When you set the tool numbering option to Tool ID, the tool number is automatically set to the same number as the tool ID. This is the default setting used when the tool is mounted to a milling spindle tool device.
When you set the tool numbering option to Station Number, the tool number is automatically set to the station number to which the tool is mounted. This is the default setting used when the tool is mounted to a turret tool device.
The manual tool numbering option allows you to set the tool number either manually or using the number from the tool library. When you select the manual option, the Tool Number box becomes available for editing, and the initial tool number value is set using the number stored with the tool in the tool library, but you can then type the tool number into the Tool Number box to update this value. (After changing the tool number from the value stored in the tool library, the new value is retained.)
It is important to understand that the Auto Tool Numbering by Device setting defined for the machine in the Current Settings Default determines how the stations of the machine's tool devices are numbered in the Tool Crib. This determines how the automatic Tool ID and Tool Numbering options work.
With the setting turned off, all tool devices are considered globally meaning each station has a unique number. For example, a machine with two sixteen-station turrets results in station numbers 1-16 (turret 1) and 17-32 (turret 2).
With this setting turned on, all tool devices are considered individually (by device). For example, a machine with two sixteen-station turrets results in station numbers 1-16 (turret 1) and 1-16 (turret 2).
The following provides an example tool numbering/tool ID output based on using the default settings for a single turret machine and a job using four tools. (The default settings are Use Automatic Tool ID and Use Station #.)
Station |
1 |
Output |
Substation |
1. Side face |
T0101 |
Adapter Station |
TMP 1 |
Tool Number Setting |
Use Station # |
Tool ID |
1 |
Tool Number |
1 |
Station |
3 |
Output |
Substation |
1. Side face |
T0302 |
Adapter Station |
TMP 1 |
Use Station # |
Tool ID |
2 |
Tool Number |
3 |
Station |
5 |
Output |
Substation |
1. Side face |
T0503 |
Adapter Station |
TMP 1 |
Use Station # |
Tool ID |
3 |
Tool Number |
5 |
Station |
5 |
Output |
Substation |
1. Side face |
T0504 |
Adapter Station |
TMP 2 |
Use Station # |
Tool ID |
4 |
Tool Number |
5 |
