Pattern
This topic explains the options found in the Pattern page of the Mill 2 Axis Wizard for the following operations:
- Profile Finish
- Chamfer Mill
This topic also provides links to related topics.
Patterns
Patterns
Standard- creates a toolpath for cutting the perimeter of one or more contours at a constant depth. (This is the only option available for Finish operations.)
Compensation
System Compensation
With this option On, the system offsets the geometry by the tool radius. With this option Off, you should use Machine Compensation.
- Off - the toolpath is calculated from the center line.
- Left - the toolpath is calculated to the left of the selected contour.
- Right - the toolpath is calculated to the right of the selected contour.
These options only effect the output in the posted code.
- Comp Left (G41) - the toolpath of the operation represents the center of the cutter. The post processed code includes the command for cutter compensation to the left of the contour.
- Comp Right (G42) - the toolpath of the operation represents the center of the cutter. The post processed code includes the command for cutter compensation to the right of the contour.
*For more information on how to use compensation, see the Compensation topic.
MDI (Manual Data
Input)
View the MDI topic.
Clicking Next> > takes
you to the next page of the Mill 2 Axis Wizard. To move to the corresponding
topic, click the appropriate link below.
The Profile Rough Parameters page
The Profile Finish Parameters page
The Pocket Parameters page
The Facing Parameters page
The Engrave Parameters page
The Chamfer Mill Parameters
page
The Plunge Rough Parameters
page
The Corner Rounding Parameters page
