The Mill 4 Axis Rotary Wizard Machining Strategy
The Machining Strategy page
4 Axis Rotary
4 Axis Advanced Rough
4 Axis Advanced Finish
4 Axis Rough and Finish
Current Operations
Available Operations
4 Axis Rotary
4 Axis Rotary
  1. The Templates provide predefined groups of operations that can be applied to a feature. Select a template to populate the Current Operations list. (You can customize the DMS Defaults to define the default operations for each template.)
  1. The Available Operations list displays all operations that exist for the selected feature type. After selecting a template, you can use the Available Operations to ad operations to the Current Operations.
  1. Finally, you can reorder and/or remove operations from Current Operations to define all of the operations for the feature. (You can modify this list at any time, for example, when editing the feature.)
Machining Strategy Buttons
  • (Add Operation) - adds the selected Available Operations to Current Operations.
  • (Delete Operations) - removes the selected Current Operations from the list.
  • (Move Up) - moves the selected Current Operation up one level.
  • (Move Down) - moves the selected Current Operation down one level.
Apply to All Features
Related Topic
Click Next> > to move on to The Mill 4 Axis Rotary Wizard Posting Settings
