Avoid contact point on tip - Deburring
This new option allows you to automatically tilt the tool so the tip is not used in the deburring process. Since the very tip of the tool is the least efficient contact point in material removal, this is the perfect way to avoid it without needing to actively choose a specific contact point to use!
Need Additional Help?
Was this article helpful?
