Remove Stock Pillars
The new Remove Stock Pillars option, for the Advanced Rough Adaptive pattern, allows you to finish the last of the stock on a given depth by leaving a cylinder of stock which is then finished with a single spiral ramp motion. This helps eliminate adverse cutting conditions, like vibrations and heat generation in small areas, which can be created when the pattern whittles down the stock to a thin walled island before finishing it off. With this new option, you can create optimal cutting conditions and help extend tool life.
 Remove Stock Pillars  Remove Stock Pillars
Need Additional Help?
Was this article helpful?
