Redesigned Tool Crib
With our redesigned Tool Crib, you no longer need to open the Tool Library as a separate window and add your tools one at a time! The Tool Library is visible in the same window, you can select multiple tools to drag into the crib at the same time, and even save tools from the Tool Crib to your Tool Library for the first time!
Old Tool Crib
NewΒ Tool Crib
Need Additional Help?
Was this article helpful?
