Copy Machine Setups
Copy Machine Setups
In this latest version copying and pasting entire machine setups is possible! In some cases, when building a machine setup, another machine setup is needed and the same features and settings, or many of them can be applied to the new setup. Now, you can save a huge amount of time by simply copying and pasting to recreate the existing machine setup.
Need Additional Help?
Was this article helpful?
