User defined tool orientation on lead-in/ lead-out
In order to give you as much control as possible, this new feature allows you to set how the tool is oriented moving into or out of the lead moves! Just set the Tool axis orientation to User defined direction, and choose between x, y, z, or user defined to choose anything in between! The tool will then move through the lead an morph into the orientation defined for the operation.
Need Additional Help?
Was this article helpful?
