Edit Toolpath - Break
This topic explains the Parameters available when the Break Command Mode, which allows you to split toolpath entities into multiple segments, is used. As explained in the Edit Toolpath Dialog topic, most of the Edit Toolpath dialog remains the same, no matter which Command Mode is being used. It is the Parameters of the Break Command Mode this topic focuses on, although, the Command Mode group, Selected Toolpath Elements group and the Animation group can still be revisited in this topic by expanding the drop down hot spots of the same name.
To work through an example utilizing this function, see the Edit Toolpath Example - Break.
Actions
Command Mode
  • Preview
  • Point Pick
  • Convert Selected Toolpath to CAD Geometry - This button will create CAD geometry on the active layer from the selected toolpath entities.
  • Divide - will divide the selected toolpath elements by the number of divisions entered.
    • Number of Divisions - sets the amount of evenly spaced toolpath elements that will take the place of the original selected toolpath elements.
  • Screen Point - will allow you to click on the selected toolpath elements in the graphics area to define a break point.
Tip: Once a point is placed, you can click and hold to drag it into another position. Release the mouse to place it in its new location.
    • Distance - allows you to set a particular distance to a break point, or group of break points. Simply highlight a Break Point in the list above, to assign a distance to that particular point.
      • % - use this toggle to switch between setting the Distance as a percentage of the toolpath segment, or an absolute distance from the start of the toolpath segment.
  • Apply to all - sets the current break distance to all break points listed in the Screen Point group.
Animation
  • Animation
Edit Toolpath Delete
Edit Toolpath Trim and Relink
Edit Toolpath Move
Edit Toolpath Replace
Edit Toolpath Extend Cut Move
Edit Toolpath Edit Tool Axis
