Edit Toolpath - Modify Attributes
This topic explains the Parameters available when the Modify Attributes Command Mode, which allows you to modify the feedrate, or feed type, is used. As explained in the Edit Toolpath Dialog topic, most of the Edit Toolpath dialog remains the same, no matter which Command Mode is being used. It is the Parameters of the Modify Attributes Command Mode this topic focuses on, although, the Command Mode group, Selected Toolpath Elements group and the Animation group can still be revisited in this topic by expanding the drop down hot spots of the same name.
To work through an example utilizing this function, see the Edit Toolpath Example - Modify Attributes.
Actions
Command Mode
  • Preview
  • Point Pick
  • Convert Selected Toolpath to CAD Geometry - This button will create CAD geometry on the active layer from the selected toolpath entities.
  • Type -allows you to alter the feedrate of the selected toolpath entities. Choose between:
    • Rapid - converts the selected toolpath element(s) to a rapid move.
    • Plunge Feed - assigns the selected toolpath element(s) the plunge feedrate of the operation.
    • Cutting Feed - assigns the selected toolpath element(s) the cutting feedrate of the operation.
    • User Defined - allows you to enter a specific value to use as the feedrate for the selected toolpath element(s).
  • Feedrate - When the User Defined type is selected, this will allow you to enter a specific speed to use for the selected toolpath elements.
  • Apply to All - assigns the selected feedrate to all toolpath elements in the Selected Toolpath Element list, once executed.
Animation
  • Animation
Edit Toolpath Delete
Edit Toolpath Trim and Relink
Edit Toolpath Move
Edit Toolpath Replace
Edit Toolpath Break
Edit Toolpath Extend Cut Move
Edit Toolpath Edit Tool Axis
