Edit Toolpath - Replace
This topic explains the Parameters available when the Replace Command Mode, which aallows you to draw in your own toolpath and replace entities of the toolpath with this CAD geometry, is used. As explained in the Edit Toolpath Dialog topic, most of the Edit Toolpath dialog remains the same, no matter which Command Mode is being used. It is the Parameters of the Replace Command Mode this topic focuses on, although, the Command Mode group, Selected Toolpath Elements group and the Animation group can still be revisited in this topic by expanding the drop down hot spots of the same name.
To work through an example utilizing this function, see the Edit Toolpath Example - Replace.
Actions
Command Mode
  • Preview
  • Point Pick
  • Convert Selected Toolpath to CAD Geometry - This button will create CAD geometry on the active layer from the selected toolpath entities.
  • Toolpath Chain - lists all entities or edges to replace the Selected Toolpath Elements with.
  • Pick - enables you to select wireframe entities or edges to add to the Toolpath Chain list.
  • Link - allows you to set the method of connection between the existing toolpath and the Toolpath Chain that replaces the Selected Toolpath Elements.
    • Direct Rapid -connects the selected Toolpath Chain with a rapid move.
    • Direct Feed - connects the selected Toolpath Chain with a feed move.
    • Direct Auto - looks at the entities connecting to the entities being replaced and the replacements themselves to try to determine the best method of connection to use.
Animation
  • Animation
Edit Toolpath Delete
Edit Toolpath Trim and Relink
Edit Toolpath Move
Edit Toolpath Break
Edit Toolpath Extend Cut Move
Edit Toolpath Edit Tool Axis
