Edit Toolpath - Delete
This topic explains the Parameters available when the Delete Command Mode, which allows you to delete toolpath entities and relink the toolpath, is used. As explained in the Edit Toolpath Dialog topic, most of the Edit Toolpath dialog remains the same, no matter which Command Mode is being used. It is the Parameters of the Delete Command Mode this topic focuses on, although, the Command Mode group, Selected Toolpath Elements group and the Animation group can still be revisited in this topic by expanding the drop down hot spots of the same name.
To work through an example utilizing this function, see the Edit Toolpath Example - Delete.
Actions
Command Mode
  • Preview
  • Point Pick
  • Convert Selected Toolpath to CAD Geometry - This button will create CAD geometry on the active layer from the selected toolpath entities.
Link
  • Retract / Plunge - will retract from the exiting position in the trimmed toolpath to a defined Z plane with a rapid move. This will be followed by an X,Y rapid move to the next location, at which point the tool will rapid down to the feed plane above the next cut, and finally feed into the next cut using the plunge feedrate.
  • Direct Feed- Connects the gaps with a single linear feed move set to the cutting feedrate.
  • Direct Rapid  - Connects the gaps with a single linear rapid move.
Retract
When Retract / Plunge is chosen as the Link option, this value allows you to set the Z plane height to be retracted to for the toolpath elements being adjusted.
  • Rapid Plane - will retract the tool to the Rapid Plane of the feature, which is an incremental value from the Top of Feature.
  • Feed Plane - will retract the tool to the Feed Plane as defined in the feature.
  • Custom - will allow you to set a specific Rapid Plane and Feed Plane value to define the Retract / Plunge movements.
    • Rapid Plane - sets the custom Rapid Plane value to be used.
      • Absolute or Incremental- This toggle button determines how this data is interpreted. Set this option to read the Rapid Plane as either an Absolute or an Incremental value.
    • Feed Plane - sets the custom Feed Plane value to be used.
      • Absolute or Incremental - This toggle button determines how this data is interpreted. Set this option to read the Feed Plane as either an Absolute or an Incremental value.
  • Extension
    - With this check box cleared, the ends of the selected toolpath elements will be left as they are. The selected linking options will occur from that position.
    - With this check box selected, you will be creating a linear extension which is tangent to the previous toolpath entity. The selected linking options will occur from this new position.
Extension
Extension
  • % of Tool or Absolute - This toggle button determines how this data is interpreted. Set this option to read the entered extension as either a percentage of the tool diameter or an absolute value.
Animation
  • Animation
Edit Toolpath Trim and Relink
Edit Toolpath Move
Edit Toolpath Replace
Edit Toolpath Break
Edit Toolpath Extend Cut Move
Edit Toolpath Edit Tool Axis
