The Mill 2 Axis Wizard Machining Strategy
The Machining Strategy page
  1. The Templates provide predefined groups of operations that can be applied to a feature. Select a template to populate the Current Operations list. (You can customize the DMS Defaults to define the default operations for each template.)
  1. The Available Operations list displays all operations that exist for the selected feature type. After selecting a template, you can use the Available Operations to ad operations to the Current Operations.
  1. Finally, you can reorder and/or remove operations from Current Operations to define all of the operations for the feature. (You can modify this list at any time, for example, when editing the feature.)
Machining Strategy Buttons
  • (Add Operation) - adds the selected Available Operations to Current Operations.
  • (Delete Operations) - removes the selected Current Operations from the list.
  • (Move Up) - moves the selected Current Operation up one level.
  • (Move Down) - moves the selected Current Operation down one level.
Apply to All Features
Save to Defined Template
In addition to altering the existing Strategies, you can also create your own with the Save to Defined Template option. To learn more, see the Defined Templates topic.
If you are creating tabs, you can click Next>> to go to the Tabs Settings. If no tabs are being used, click Next>> twice to go to The Posting Dialog Box.
The current operations that you selected are created and added to the tree on the left side of the Milling Wizard.
