The CAM Defaults Overview
The CAM Default folder that displays at the top of the CAM Tree contains commands to many default CAM settings as well as job creation. These commands are accessed by using the right-click shortcut menu.
Default Machining Settings and Job Creation
To display a shortcut menu with the following items, right-click CAM Defaults.
CAMDefaultsIcon.png CAM Defaults
NOTE:      There are a few default CAM settings, such as machining tolerances, in the Settings Default and/or Settings Part dialog boxes.
The CAM Overview
The Milling Job
The Turning Job Overview
The Wire EDM Job
The Nesting Job
