Keyboard Shortcuts for BobCAD-CAM Post Processor Utility
Or, Click on items in “Program Blocks” tree folder
Keyboard Shortcuts:
for Visual Studio Code
Download a PDF version: HERE
Specific for BobCAD-CAM Post Processor Utility
Format Post Processor
SHIFT + ALT + F
Debug_on/off
CTRL + ALT + D
Go to Post Block
CTRL + ALT + F
Append Revision Log
CTRL + ALT + A
Refresh Post Blocks Tree
CTRL + ALT + R
Note: Should not be needed as the tree should auto-refresh
Go to Program Block CTRL + Left-click on program_block_# or lua_block_#
VSCode Default Shortcuts
Compare 2 files
In Explorer with Folder opened,
  1. Right-click on first file you want to compare and click, “Select for Compare”
  2. Right-click on your second file and click, “Compare with Selected”
Comment Toggling
CTRL + /
VSCode Command Palette
SHIFT + CTRL + P
Note: Type “bobcad” to see list of all commands
Duplicate Line Up/Down
SHIFT + ALT + up/down arrow
Multi-Select the Same word
CTRL + D
Highlight all instances of a word
CTRL + SHIFT + L
Split Screen
CTRL + ALT + left/right arrow
Note: Same as “Move to Other View” in Notepad++
Zoom In/Out
CTRL + = (Zoom In)
CTRL + - (Zoom Out)
CTRL + numpad 0 (Reset Zoom)
Add multiple cursor locations to edit at the same time
ALT + Left-Click
CTRL + U (Undo cursor location)
Reopen Closed Tab
CTRL + SHIFT + T
New Blank File
CTRL + N
Load new instance of VSCode
CTRL + SHIFT + N
Duplicate/Copy Opened File in Separate Instance of VSCode
CTRL + K release then, O
Duplicate File in same instance of VSCode
CTRL + \
CTRL + 1/2 (Switch between tabs)
See all Code Snippets, Post Vars and Post APIs
CTRL + Space
Open Active Files in VSCode Explorer
With the Explorer opened, click the 3 dots at the top and enable, "Open Editors"
This is good when you have two files you want to compare that are in separate folders.
Useful Links
Post Processor Help System
LINK
Bobcad API Lua Plugin Help System
LINK
Setup MoonSharp Debug for Lua Plugins
LINK
All Post Processor Documentation (PDFs)
Go to the following folder on your computer: C:\BobCAD-CAM Data\BobCAD-CAM V(Version #)\Posts\Documentation
More VSCode Shortcuts (PDF) LINK
