SOLIDWORKS MBD – Model Based Definitions
SOLIDWORKS MBD is an integrated drawingless manufacturing solution for SOLIDWORKS. It helps companies define, organize, and publish 3D Product Manufacturing Information (PMI) including 3D model data in industry standard file formats such as 3D PDF and eDrawings®. Unlike traditional 2D drawings, SOLIDWORKS MBD guides the manufacturing process directly in 3D, which helps streamline production, cut cycle time, reduce errors, and support industry standards such as Military-Standard-31000A, ASME Y14.41, ISO 16792, and DIN ISO 16792.
Define PMI directly in 3D
SOLIDWORKS MBD defines PMI directly in 3D and avoiding the expensive, time-consuming, and risky 2D drawing detour, which can save up to one-third of the total engineering dollars. 3D PMI also helps speed up communication, cut quoting time, and reduce errors thanks to its 3D data interrogation, interactivity, and rich Meta properties.
Clean and Structured 3D Presentation
Beyond 3D PMI Definition, SOLIDWORKS MBD helps organize the rich data into clean and structured 3D presentations with different views and display settings. It can even intelligently show and hide 3D annotations while you rotate the model to give you extra clarity while respecting all the critical-to-function annotations. Messy display? Tedious navigation? Missing annotations? Problems solved!
Customize 3D Output Templates
Serve multiple deliverables and departments by customizing the 3D Output Templates. You can build the layout, insert company or group logo, position the 3D View port and thumbnails, edit the text descriptions, embed Meta property links, and add tables. SOLIDWORKS MBD covers them all. Once they are set up, these templates will serve as internal and external process guidelines for all departments, such as Manufacturing, Operations, QA, and Procurement on multiple deliverables, such as engineering drawings, Request for Quote (RFQ), inspection report, and work instructions. In addition, SOLIDWORKS MBD delivers a comprehensive set of predefined templates to use out of the box.
Easy 3D output and distribution
SOLIDWORKS MBD publishes widely accepted file formats such as eDrawings® and 3D PDF according to the predefined or customized templates. eDrawings files can be opened in a free eDrawings Viewer and 3D PDF can be viewed in a free Adobe Reader which is installed on 93% of Internet connected machines. In addition to 2D information such as engineering notes, BOM, and rich Meta properties (Part Numbers, Materials, and Approvals), you can also interrogate the model in 3D with Pan, Zoom, Rotate, Measure, Section, and other 3D tools. The easy and popular 3D output provides additional clarity to help reduce errors, speed up communication, and cut cycle time.
Comply with industry standards
SOLIDWORKS MBD helps comply with the predominant industry standards, such as ASME Y14.41, Military-Standard-31000A, ISO 16792, and so on. This compliance gives you the competitive advantages to win more contracts and deliver projects to strict requirements, on time and on budget. Customers looking to meet United States Government standards will be encouraged by the assessment of Rich Eckenrode, Co-Chairman of the Military-Standard-31000 manufacturing sub-committee. “SOLIDWORKS MBD’s compliance to Military-Standard-31000 Appendix B is close to 100% …”.
Share and Archive intelligent and intuitive 3D data
SOLIDWORKS MBD helps you share and archive intuitive 3D data, including the models, PMI, views, and Meta properties, so that you and your suppliers don’t have to waste time in re-modeling based on traditional 2D Drawings. With the 3D data, you can upgrade your legacy product configurations to new models much faster and design tooling and fixtures much more easily.
Need Printouts or 2D drawings? No problem.
SOLIDWORKS offers intuitive print support for both native files and 3D output. SOLIDWORKS MBD also delivers print-friendly templates for the best results. Furthermore, SOLIDWORKS MBD seamlessly integrates with SOLIDWORKS 2D Drawings. The PMI and Views created in 3D are readily available for reuse in 2D, which can save you time and fit well into existing processes.
3D PRODUCT MANUFACTURING INFORMATION (PMI) DEFINITION
SOLIDWORKS
MBD Standard
SOLIDWORKS
S Standard
Intelligent Dimensioning, Tolerancing, and Annotation (DimXpert) Freestyle Dimensioning, Tolerancing, and Annotation (Reference Dimensions) Comprehensive Bill of Materials (BOM)
YES
YES
3D PMI ORGANIZATION
3D Annotation Views
YES
YES
Automatic show and hide annotations as a model rotates
YES
YES
3D Views capturing Annotation Views, Configurations, Display States, Section View, and other View Settings
YES
NO
3D Model Break Views
YES
NO
3D OUTPUT
Publish to eDrawings
YES
YES
3D Output Template Customization
YES
YES
Rich Predefined 3D Output Templates
YES
NO
3D PDF with 3D PMI, Views & Meta Properties
YES
NO
