Open Source Sofware
BobCAM for SOLIDWORKS™ V7
TOOLPATH MATRIX
2.5 AXIS
TOOLPATH
EXPRESS3 AXIS
STANDARD
3 AXIS
PRO
3 AXIS
PREMIUM
4 AXIS
STANDARD
4 AXIS
PRO
5 AXIS
STANDARD
5 AXIS
PRO
Profiling & Pocketing
Engraving
Thread Milling
Plunge Roughing
Facing
Chamfering
Rest Machining
Drilling & Tapping
Drag Knife
High Speed Pocketing
Morph Spiral Pocketing
Parallel Pocketing
Offset In Pocketing
 Requires 3 AXIS Pro or Premium & Above
3 AXIS
TOOLPATHS
EXPRESS3 AXIS
STANDARD
3 AXIS
PRO
3 AXIS
PREMIUM
4 AXIS
STANDARD
4 AXIS
PRO
5 AXIS
STANDARD
5 AXIS
PRO
Planar
Spiral
Radial
3D Plunge Roughing
Z-Level Roughing
Advanced Z Level Finishing
Project Curves
Advanced Planar
Flatlands
Equidistant Offset
Pencil
High Speed Roughing
Rest Machining
Parallel Pocketing
Offset In Pocketing
 Requires 3 AXIS Premium & Above
SURFACE BASED TOOLPATHS
(3,4, & 5 AXIS OUTPUT)
EXPRESS3 AXIS
STANDARD
3 AXIS
PRO
3 AXIS
PREMIUM
4 AXIS
STANDARD
4 AXIS
PRO
5 AXIS
STANDARD
5 AXIS
PRO
Flowline
Parallel Cuts
Cuts Along Curve
Morph Between 2 Curves
Parallel to Multiple Curves
Project Curves
Morph Between Surfaces
Parallel to Surface
4 AXIS
TOOLPATHS
EXPRESS3 AXIS
STANDARD
3 AXIS
PRO
3 AXIS
PREMIUM
4 AXIS
STANDARD
4 AXIS
PRO
5 AXIS
STANDARD
5 AXIS
PRO
Indexing
Wrapping
Rotary
4 Axis Advanced Rough
4 Axis Advanced Finish
5 AXIS
TOOLPATHS
EXPRESS3 AXIS
STANDARD
3 AXIS
PRO
3 AXIS
PREMIUM
4 AXIS
STANDARD
4 AXIS
PRO
5 AXIS
STANDARD
5 AXIS
PRO
Trimming
Indexing
Swarf Machining
High Speed Multiaxis Roughing
Rest Machining
