Tool Library Manager
This topic will explain the Tool Library Manager, explain where the tool library manager can be accessed from, explain the options found in it, and provide links to related topics.
The Tool Library Manager
The Tool Library Manager contains all of the available libraries and system tools based on the main categories Drill, Mill, Lathe, Laser, Plasma, Waterjet, and Generic. This dialog is used to manage all available libraries and their contents. You can also load tool information from a previously saved file. On the left side of the dialog is a list of the available libraries, and supported tool types. The right side contains a list of tools, and displays the parameters of individual tools.
Tip: To learn about all the functionality available in the Tool Library Manager, see the Tool Library Manager Functionality topic.
Taking the time to create all of the tools in your shop(s) can greatly speed up the process of creating features. You can then add the tools to the Tool Crib to quickly create the equivalent of the tool changer for each job. The Tool Crib tool list can be saved to a file for repeated use.
- In the CAM Ribbon, click
Tool Library.
- In the CAM
Tree, right-click
CAM Defaults, and click Tool Library.
This method is used to view, add, or modify libraries and tools in the Tool Library Manager.
In the CAM
Tree, right-click
Milling Tools,
Turning Tools, or
Mill Turn Toolsand click Tool Library.
Note: This opens the Tool Library Manager showing only tools for the selected job type (Mill, Lathe, or both in the case of a Mill Turn job).
- In the Tool Crib dialog, the tools in the library available for the current operation are shown at the bottom of the Tool Crib.
The Dialog Parameters
From this dialog you can view, add, delete, and copy libraries and their tools, and edit existing tools in the Tool Parameters dialog on the right, add and delete tools.
Tool Library(s)
The section on the left controls the libraries themselves.
New - creates an empty library in your list of available libraries.
Delete - removes the selected libraries.
Rename - allows you to update the name of the selected library.
Copy To Other(s) - copies the selected library into other libraries. Launches the Copy tools to other libraries dialog.
Clone - creates a copy of the selected library.
Merge - displays the Open dialog allowing you to navigate to and merge a previously saved Tool Library, or MachiningCloud file (.mtools, .ltools, .xml or .zip). This option will add the selected tools in the library file into the previously selected library. In the case of using the MachiningCloud .zip, selecting and opening the file will launch the MachiningCloud Import dialog.
Import - displays the Open dialog allowing you to navigate to and load a previously saved Tool Library, or MachiningCloud file (.mtools, .ltools, .xml or .zip). This option will add the selected tool library file into your available libraries. In the case of using the MachiningCloud .zip, selecting and opening the file will launch the MachiningCloud Import dialog.
Current Tool Library
The section on the right controls the tools in the selected library.
Add tool - automatically creates a default tool and places it in the Tool Parameters section to allow you to modify it.
Delete tool - removes the selected tools.
Clone tool - creates a copy of the selected tools.
Copy to other libraries - creates a copy of the selected tools into other libraries.
OK - confirms the changes made to the tools and closes the Tool Library dialog.
Cancel - closes the Tool Library dialog without saving any changes made to the library.
Tip: To share libraries between work stations, you can find the sharable files in the C:\BobCAD-CAM Data\BobCAD-CAM V37\Technology\ToolLibrary directory. By default, software is installed on the C: drive. If you have installed on a separate drive, update the above directory accordingly.
Note: The available Tool Parameters vary depending on the type of tool selected. Click on a tool to display the Tool Parameters for that particular tool.
Drill
Center Drill
Tool Parameters
Tool Holder
- Holder
Label - displays the name of the associated tool holder.
When blank, no tool holder is associated.
- Assign/Remove Tool Holder - When no tool holder has been assigned, the Holder Label will be blank, and the button will read: Assign Tool Holder. This will open The Milling Tool Holder Library to allow you to select, or create a tool holder to associate with the selected tool. Once a tool holder has been assigned, the button will read: Remove Tool Holder. This will remove the association between the tool holder and the selected tool.
Feeds and Speeds
- Use System
Feeds and Speeds
Clear this check box to type feeds and speeds values manually.
- Spindle Speed/RPM - is the revolutions
per minute of the spindle.
- Plunge Feedrate - is the downward feedrate. This value is linked to the Plunge Feed per Tooth.
Custom Geometry
- Assign Tool Geometry - hides the Tool Library and opens the Tool Shape Picking dialog to allow you to select geometry from the graphics area to assign as the shape of the tool. You can learn more about assigning custom tools in the Assigning Custom Tools topic.
Drill
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Spiral Tap
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Point Tap
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Hand Tap
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Rolling Tap
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Chamfer Tool
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Counterbore
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Reamer
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Boring
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Mill
Endmill Rough
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
- Cutting Feedrate - is the feedrate for feed moves.
Custom Geometry
Endmill Finish
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Chamfer Mill
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Corner-Round
When defining a corner rounding tool, the diameter must be greater than or equal to the small diameter plus twice the corner radius.
Diameter >= Small Diameter + (Corner Radius * 2)
If you enter values that do not fit this equation, an error message displays.
Tip: When defining a corner rounding tool, if the Diameter is greater than the current/default value, set the Diameter value first. This allows you to avoid receiving the error message. If the Diameter is less than the current/default value, set the Corner Radius first to avoid the error message.
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Thread Mill
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Single Point Thread
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
V-Tool
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Tapered
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
T-Cutter
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Dove Mill
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Lollipop
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Drag Knife
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Barrel-Standard
Note: To get a more in depth look at the barrel tool type, see the Barrel Mills topic.
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Important: The following rules apply when creating a valid tool shape:
• Profile radius must be greater than the corner radius
• Diameter must be equal to or greater than the upper diameter
Barrel-Advanced
Note: The Advanced barrel type has several parameters that present a choice on how you would like to define the tool. To get a more in depth look at these options, see the Barrel Mills topic.
Tool Parameters
Important: (8): This value will typically be negative, unless the arc and its center are on the same side of the revolved axis. See Barrel Mills.
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
• Diameter must be greater than or equal to the Shaft diameter
• Diameter must be greater than the reference diameter for the barrel mill
• Profile position by (Radial): Distance (M)
• Profile radius must be greater than the radial distance of the profile
• Profile position by (Axial): Distance (M)
• Profile radius must be greater than the axial distance of the profile
• Profile position by (Axial): Reference diameter
• Profile radius must be greater than the radial distance of the profile plus the reference radius
• Flute height by: Upper diameter
• Profile radius must be greater than the radial distance of the profile plus the upper radius
• Flute height by: Length
• Profile radius must be greater than flute length minus the axial distance of profile
Barrel-Tangent
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Barrel-Lens
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
• Convex Tip Radius must be greater than, or equal to, half of the tool Diameter
Barrel-Taper
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
• Taper angle must be greater than 0.1, and less than 89
• Profile Radius must be greater than half of the Diameter
• Corner Radius must be less than half of the Diameter
• Upper Radius must not exceed half of the Diameter
Barrel-Double
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
Barrel-Section
Tool Parameters
Tool Holder
- Holder
Feeds and Speeds
- Use System
Feeds and Speeds
Custom Geometry
• Upper Corner Radius must be smaller than the Flute Length
• Lower Corner Radius must be smaller than the Flute Length
• Upper Corner Radius must be smaller than the Profile Radius
• Lower Corner Radius must be smaller than the Profile Radius
• Distance(M) Axial must be lower than the Flute Length
• Profile Radius must be greater than Distance(M) Axial
• Diameter must be greater than the Shaft Diameter
Turning
Lathe Rough / Finish / Boring
Tool
- Tool
Label - adds a name to the tool, in the tool list,
that allows you to easily identify the tool.
- Tool Number - sets the assigned tool number
- Offset Register - sets the register on the machine that
stores the diameter offset values for the tool.
Insert
Note: The following Parameters section differs depending on whether the System Shape or the Custom Shape radio button is selected. Below you will find a separate Parameters section for each option.
System Shape - uses the following parameters to set the shape designation of the insert.
• Shape - dictates the shape designation of the insert. | • Clearance - dictates the clearance designation of the insert. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Tolerance - sets
the tolerance designation of the insert. This does not affect
toolpath or output.
- Type - sets the type designation of the insert. This does not affect toolpath or output.
• Reference Point - allows you to choose an alignment of the reference point to the insert. |
- Nose Radius - sets
the radius of the tool nose.
- IC Diameter - sets the internal circumference
of the insert.
- Thickness - dictates the distance between the front cutting edge to the back of the insert.
Custom Shape - allows you to select geometry from the graphics area to define the shape of the insert.
- Assign Tool Insert - When
Custom Shape is selected, clicking the Assign Tool Insert button will
hide the Tool Library and allow you to select Tool Insert geometry, as seen below,
from the graphics area.
Important: When
assigning insert geometry, be sure to have the reference point
defined as a point, and any interior geometry drawn as a dotted
line as shown. For more information, see the Assigning Lathe Tool Inserts topic.
- Nose Radius - sets the
- IC Diameter - sets the internal circumference of
the insert.
Holder
- Edit Tool Holder - will launch the Tool Holder Definition dialog to allow you to specify measurements for the holder, or select geometry from the Workspace in order to define the holder.
Feeds and Speeds
- Use Manual Feeds
and Speeds
- Default Feeds and Speeds are used.
- Selecting this check box will give you access to the following parameters. These will allow you to set specific Feeds and Speeds for the insert. When the insert is used in the Lathe Wizard, these will be the values that are automatically entered for the tool.
RPM - sets the feeds and speeds to revolutions per minute.
CSS - sets the feeds and speeds to a constant surface speed.
- Maximum
RPM - sets the limits of the spindle speed in the posted
NC program.
- Spindle
RPM/SFM - sets the spindle speed for the feature in revolutions
per minute or the surface feet per minute based on the selected
RPM/CSS option.
- Feedrate
- sets the feedrate for the feature.
- Maximum
NC program.
Lathe Groove / Cutoff
Tool
- Tool
Insert
- Tool Width - sets the width
of the insert.
- Tool Length - sets the
length of the insert.
- Side Angle - sets the side
angle of the insert.
- Tip Angle - sets the tip
- Reference Point - allows you to choose an alignment of the reference point to the insert, as seen below:
Left Corner |
Tip |
Right Corner |
the radius between the side and bottom of the insert.
Important: When
defined as a point. For more information, see the Assigning Lathe Tool Inserts topic.
- Tool Nose Radius - sets the
Holder
Feeds and Speeds
- Use Manual Feeds
and Speeds
- Selecting this check box will give you access to the following parameters. These will allow you to set specific Feeds and Speeds for the insert. When the insert is used in the Lathe Wizard, the values below will be the values that are automatically entered for the tool.
- Maximum
NC program.
- Spindle
RPM/CSS option.
- Feedrate - sets the feedrate for the feature.
- Maximum
NC program.
- Home Position Z - sets the
Home Position in Z for the tool.
- Home Position X - sets the Home Position in X for the tool.
- Reverse Sign
- With this check box cleared, the output of the X value maintains its default behavior. A move toward the center of rotation will be output as a negative move and a move away from the center of rotation a positive move.
- With this check box selected, the output of the X value reverses. A move toward the center of rotation will be output as a negative move and a move away from the center of rotation a positive move.
Lathe Thread
Shape: LayDown | Shape: Top Notch |
Tool
The Tool data differs slightly based on the Shape chosen.
- Tool
- Offset Register - sets the register on the machine that stores the diameter offset values for the tool.
Insert
- Shape - sets the shape designation of the insert.
Lay Down |
Top Notch |
- Tool Angle - sets the angle of the insert.
Lay Down |
Top Notch |
- Tip Height - sets
the tip height of the insert when the Lay Down Shape is selected.
- Height - sets the
height of the insert when the Top Notch Shape is selected.
- Width - sets the width of the insert when the Top Notch Shape is selected.
- Reference Point - allows you to choose an alignment of the reference point to the insert.
Reference Point: Corner | Reference Point: Tip | |||
Lay Down |
Top Notch |
Lay Down |
Top Notch | |
- IC Diameter - sets the internal circumference of the insert when the Lay Down Shape is selected.
Important: When
the insert.
Holder
Feeds and Speeds
- Use Manual Feeds
and Speeds
- Maximum
NC program.
- Spindle
RPM/CSS option.
- Maximum
NC program.
- Reverse Sign
The Tool Library Functionality
Center Drill Parameters
Drill Operation Parameters
Chamfer Drill Parameters
Chamfer Mill Patterns
Ream Parameters
Bore Parameters
Rolling Tap Parameters
Counterbore Drill Parameters
Counterbore Mill Parameters
Tap Parameters
Facing Patterns
Profile Rough Patterns
Profile Finish Patterns
Pocket Patterns
Facing Patterns
Engrave Parameters
Plunge Rough (2 Axis) Patterns
Corner Rounding Patterns
Z Level Rough Patterns
Z Level Finish Patterns
Planar Patterns
Spiral Patterns
Radial Patterns
Plunge Rough Patterns
Advanced Rough Patterns
Flatlands Parameters
Equidistant Patterns
Pencil Parameters
Advanced Planar Patterns
Project Curves Patterns
Advanced Z Level Finish Patterns
4 Axis Rotary Patterns
Mill Thread Pattern
3 Axis Wireframe Parameters
Thread Parameters
Cutoff Parameters
Stock Handling Parameters
