Stock Wizard |
Rectangular Stock |
Cylindrical Stock |
Wire Frame Stock |
Solid Model Stock |
Stl Stock |
Job Based CAM Tree |
Revolved Stock |
Multiple Machine Setups |
Toolpath Pattern Array |
Toolpath Pattern Translate |
Toolpath Pattern Point |
Index System |
Wrapping Groups |
Multi-Threaded 3 Axis Pro Toolpath Calculations |
Expand and Collapse CAM Tree Items |
Dynamic Machine Strategies in the CAM Wizard |
Dynamic Posting Order |
Geometry Preview |
Operation Preview |
Default Parameter Templates |
Job Templates |
User Defined Machining Strategy Templates |
New Machining Order Dialog |
Default Machining Order Options |
CAM Tree Flyouts |
Redesigned Tool Library |
Work Offset Pattern |
Fixtures |
Mill Turn Chuck Jaws |
Subprograms for Operations |
Keep Bounding Geometry (Stock Wizard) |
Simulation Work Offset Pick Point Method |
Selection |
V32 |
Open & Close Chain Selection |
Color, Layer, Line Style |
Pick and Match |
Face and Edge Picking |
Constant Z Selection |
Loop Selection |
Toolpath Features |
V32 |
Save/Load Feature |
Copy/Paste Feature |
Keep Feature Depth |
Groups |
Locked Features |
Update All Geometry |
Toolpath Editor |
Edit Operation |
Apply To All Features/Operations |
Groups for Index Systems & Wrapping Groups |
Save Feature Defaults |
User Defined Strategy Templates |
Speed and Feeds |
V32 |
Material/Cutting Conditions |
Surface Radius Based Feed Optimization |
Tool Contact Based Feed Optimization |
Convert Rapids To Feed |
Independent Lead In/Out Feed |
Adaptive Feed Rate Volume Based |
Adaptive Feed Rate Chip Thinning Based |
Tools |
V32 |
Tool Library |
Tool Types: Tapered Endmill, T-Cutter, Dove Mill, Lollipop |
Tool Holder Library |
Tool Crib |
User Defined Tool Profiles(Form Tools) |
Single Window Tool Library |
Tool Library Search/Filter |
Simulation |
V32 |
Machine Simulation |
Setup Sheets |
Backplot |
Backplot with Detailed Information |
Toolpath Statistics |
Multi Window View |
Measure Grid |
Section View/Layering |
Click to Advance Toolpath |
Zoom Window |
Show Previous View |
Next Feed Move |
Move List Bookmarks |
Keyboard Shortcuts for ISO Views |
Machine Coordinate System Display |
Material Display Mode Retention |
CAD |
V32 |
Preview |
User Coordinates System(s) |
Dimensions |
Measure |
Text |
Text Along a Curve |
Show/Hide Axis |
Customizable Interface |
Standard View |
Section View |
Dynamic CAD |
Snap Grid |
Show/Hide Gnomon |
New Geometry Picking Interface |
Instant Preview |
Construction Lines |
Dynamic UCS |
Layer Attributes |
Auto Dimensions |
Leader Arrow Note |
CAD Tree Optimization |
Delete CAD Tree History |
Wire Frame |
V32 |
Point Sketch |
Point Coordinates |
Point Incremental |
Point End |
Point Intersection |
Point Intersection on Extension |
Point Arc Center |
Point Perpendicular |
Point On Entity |
Line Sketch |
Line Coordinates |
Line Join |
Line Tangent |
Line Parallel |
Line Angle |
Line Angle Tangent |
Line Chamfer |
Line Chamfer Single Click |
Line Continuous |
Arc Sketch |
Arc Coordinates |
Arc Snap |
Arc Fillet |
Arc Fillet Chain |
Arc Fillet Single Click |
Arc 3 Entities |
Arc Center 2 End Points |
Arc Between 2 Points Diameter |
Arc Between 2 Points Radius |
Fit Arcs |
Rectangle |
Rectangle 2 Points(Sketch) |
Rectangle 2 Points Center Top |
Rectangle 3 Points Length Width |
Rectangle 3 Points Half Length Width |
Rectangle Angle |
Ellipse |
Ellipse with Spline |
Spiral |
Contour |
Offset |
Offset Sharp Corner |
Continous Sketch |
Equalize |
Project Curves |
Hole Pattern |
Point Pattern |
Gear |
Sprocket |
Roller CAM |
Shape Library |
Shape with Origin Commands |
Spline Interpolated |
Spline Fit |
Spline Blended |
Spline Approximated |
Spline Multi Geomtery Pick Method |
Editing Tools |
V32 |
Mirror |
Rotate |
Rotate 3D |
Translate |
Trim Extend |
Break |
Extract Edges |
Extract Edges Project to Z |
Stiching |
Reorganize |
Explode |
Reverse Surface Normal |
Drag Corner |
Deform |
Stretch |
Nonuniform Scale |
2D Boolean |
Spun Profile |
Dynamic Scale/Scale Sketch Handle |
Unwrap |
Unwrap with Chain Selection |
Surfaces |
V32 |
Rectangle Plane |
Rectangle Angle |
Circular Plane |
Circular Plane 2 Points Radius |
Circular Plane 2 Points Diameter |
Circular Plane Center 2 End Points |
Circular Plane 3 Points |
Planar |
Extrude Curve |
Extrude Surface |
Revolve |
Sweep |
Cross Section |
Skin |
Offset |
3 Edge |
4 Edge |
Multi-sided Patch |
Fillet |
Extend |
Extend with Face Selection |
Intersection Curves |
UnTrim Surface |
Break Surface |
Swung |
Ruled |
Solids |
V32 |
Sphere |
Cube |
Cube with Origin Control |
Cylinder |
Torus |
Fillet/Chamfer |
Boolean Add/Subtract/Intersect |
Extrude Boss |
Extrude Cut |
Split |
Shell |
Imprint |
