BobCAD-CAM Version 37 Matrix
V33 to V37 V34 to V37 V35 to V37 V36 to V37
247 209 163 108
SUPPORTED LANGUAGES V33 V34 V35 V36 V37
ENGLISH
SPANISH
TURKISH
JAPANESE
PORTUGUESE
GERMAN
CZECH
FRENCH
ITALIAN
KOREAN
GENERAL V33 V34 V35 V36 V37
Customizable Context Menu
Notifications
2023 SOLIDWORKS File Reading
Contextual Toolbars
Migration
Pack2Go and Unpack Zip
Multiple Selection in Picking Boxes
New Feature Icons
Online Help Browser Selection
View to Active UCS
View Rotation Keys
3 AXIS MILLING V33 V34 V35 V36 V37
Optimal XY Angle for Advanced Planar
Improved Stock Aware Linking
Custom Tool Shape Recognition
Advanced UI
Over Machining
Custom Tool Shape for Advanced Roughing and Finishing
Custom Tools for Undercuts
Corner Slowdown for Equidistant
Dynamic Holder Checking
Stock has Undercuts
Start Location Control
3 Axis Deburring Introduced
UP/ Down Feedrate Control for Equidistant Offset
Trim Adaptive Passes for Advanced Planar
Barrel Mill Supported for 3 Axis Pro Toolpaths
CAD V33 V34 V35 V36 V37
Tanget Tangent Radius
Create UCS Based on Machine Setup
Contextual Help
Measure Solid: Solid is Manifold
Select Layer(s) Dialog
Copy Face
Extruded Body Interaction Options
Modification Doodad
Extract Isocurve
Selection Manager
Silhouette
Solid Chamfer by Width
Layer Manager Updates
Arc Radius or Diameter Text Field
Project Curves: Direction
Project Curves: Curves on Curves
Line Join to closest snap point
Solid edge mid-pint snap
Align to Coordinate System
Add / Edit Hole Property
Advanced Holes
CAM V33
Stock Wizard
Rectangular Stock
Cylindrical Stock
Wire Frame Stock
Solid Model Stock
Stl Stock
Job Based CAM Tree
Revolved Stock
Multiple Machine Setups
Toolpath Pattern Array
Toolpath Pattern Translate
Toolpath Pattern Point
Index System
Wrapping Groups
Multi-Threaded 3 Axis Pro Toolpath Calculations
Expand and Collapse CAM Tree Items
Dynamic Machine Strategies in the CAM Wizard
Dynamic Posting Order
Geometry Preview
Operation Preview
Default Parameter Templates
Job Templates
User Defined Machining Strategy Templates
New Machining Order Dialog
Default Machining Order Options
CAM Tree Flyouts
Redesigned Tool Library
Work Offset Pattern
Fixtures
Mill Turn Chuck Jaws
Subprograms for Operations
Keep Bounding Geometry (Stock Wizard)
Simulation Work Offset Pick Point Method
Selection V32
Open & Close Chain Selection
Color, Layer, Line Style
Pick and Match
Face and Edge Picking
Constant Z Selection
Loop Selection
Toolpath Features V32
Save/Load Feature
Copy/Paste Feature
Keep Feature Depth
Groups
Locked Features
Update All Geometry
Toolpath Editor
Edit Operation
Apply To All Features/Operations
Groups for Index Systems & Wrapping Groups
Save Feature Defaults
User Defined Strategy Templates
Speed and Feeds V32
Material/Cutting Conditions
Surface Radius Based Feed Optimization
Tool Contact Based Feed Optimization
Convert Rapids To Feed
Independent Lead In/Out Feed
Adaptive Feed Rate Volume Based
Adaptive Feed Rate Chip Thinning Based
Tools V32
Tool Library
Tool Types: Tapered Endmill, T-Cutter, Dove Mill, Lollipop
Tool Holder Library
Tool Crib
User Defined Tool Profiles(Form Tools)
Single Window Tool Library
Tool Library Search/Filter
Simulation V32
Machine Simulation
Setup Sheets
Backplot
Backplot with Detailed Information
Toolpath Statistics
Multi Window View
Measure Grid
Section View/Layering
Click to Advance Toolpath
Zoom Window
Show Previous View
Next Feed Move
Move List Bookmarks
Keyboard Shortcuts for ISO Views
Machine Coordinate System Display
Material Display Mode Retention
CAD V32
Preview
User Coordinates System(s)
Dimensions
Measure
Text
Text Along a Curve
Show/Hide Axis
Customizable Interface
Standard View
Section View
Dynamic CAD
Snap Grid
Show/Hide Gnomon
New Geometry Picking Interface
Instant Preview
Construction Lines
Dynamic UCS
Layer Attributes
Auto Dimensions
Leader Arrow Note
CAD Tree Optimization
Delete CAD Tree History
Wire Frame V32
Point Sketch
Point Coordinates
Point Incremental
Point End
Point Intersection
Point Intersection on Extension
Point Arc Center
Point Perpendicular
Point On Entity
Line Sketch
Line Coordinates
Line Join
Line Tangent
Line Parallel
Line Angle
Line Angle Tangent
Line Chamfer
Line Chamfer Single Click
Line Continuous
Arc Sketch
Arc Coordinates
Arc Snap
Arc Fillet
Arc Fillet Chain
Arc Fillet Single Click
Arc 3 Entities
Arc Center 2 End Points
Arc Between 2 Points Diameter
Arc Between 2 Points Radius
Fit Arcs
Rectangle
Rectangle 2 Points(Sketch)
Rectangle 2 Points Center Top
Rectangle 3 Points Length Width
Rectangle 3 Points Half Length Width
Rectangle Angle
Ellipse
Ellipse with Spline
Spiral
Contour
Offset
Offset Sharp Corner
Continous Sketch
Equalize
Project Curves
Hole Pattern
Point Pattern
Gear
Sprocket
Roller CAM
Shape Library
Shape with Origin Commands
Spline Interpolated
Spline Fit
Spline Blended
Spline Approximated
Spline Multi Geomtery Pick Method
Editing Tools V32
Mirror
Rotate
Rotate 3D
Translate
Trim Extend
Break
Extract Edges
Extract Edges Project to Z
Stiching
Reorganize
Explode
Reverse Surface Normal
Drag Corner
Deform
Stretch
Nonuniform Scale
2D Boolean
Spun Profile
Dynamic Scale/Scale Sketch Handle
Unwrap
Unwrap with Chain Selection
Surfaces V32
Rectangle Plane
Rectangle Angle
Circular Plane
Circular Plane 2 Points Radius
Circular Plane 2 Points Diameter
Circular Plane Center 2 End Points
Circular Plane 3 Points
Planar
Extrude Curve
Extrude Surface
Revolve
Sweep
Cross Section
Skin
Offset
3 Edge
4 Edge
Multi-sided Patch
Fillet
Extend
Extend with Face Selection
Intersection Curves
UnTrim Surface
Break Surface
Swung
Ruled
Solids V32
Sphere
Cube
Cube with Origin Control
Cylinder
Torus
Fillet/Chamfer
Boolean Add/Subtract/Intersect
Extrude Boss
Extrude Cut
Split
Shell
Imprint
MILL TURN V33 V34 V35 V36 V37
Enhanced Pack2Go includes Adapter Libraries
Auto 3+ 2 Roughing
Multiaxis Finishing
3 to 5 Axis Conversion
Deburring Operation
Lathe: New Pecking Options for Hole Cycles
Lathe: Chip Breaking Cycles
Mill Turn: Chuck Wizard
Advanced Feedrates
Mill 3 Axis Wire Frame
Mill Thread
Mill Multiaxis
Mill 4 Axis Rotary
Mill 3 Axis
Mill 2 Axis
Mill Facing
Mill Counterbore Tap Hole
Mill Counterbore Hole
Mill Tap Hole
Mill Drill Hole
LATHE V33 V34 V35 V36 V37
Stock Tracking
Trim to Stock
Lathe Remove Underecut
Lathe Profile Extension
Lathe Constraints
Lathe Feature Type
Lathe End Face
Lathe Turing
Lathe Groove
Lathe Hole
Lathe Tapped Hole
Lathe Thread
Lathe Cutoff
Lathe Stock Handling
Mill Turn V33
Support for Many of the Most Popular Mill Turn / Live Tooling Machines
Multiple Turret Machine Support
Support for Subspindles
Tool Crib for Easy Mounting of Tools and Adapters
5 Axis Milling Spindle Support
Job Setup Wizard
MDI ( Manual Data Input ) for Motion, Part Transfers, Tailstocks and More
Turret and Tool Adapter Library
New Lathe System
Wire EDM V28 V29 V30 V31
Wire EDM Jobs
CAM Wizard
Stock Wizard
Wire EDM Features
2 Axis Inside, 2 Axis Outside and 2 Axis Open (No Taper)
2 Axis Inside, 2 Axis Outside and 2 Axis Open (Constant Taper)
Land and Taper (Land on Top or Bottom)
Cut One or More Profiles in a Single 2 Axis Feature
4 Axis Inside, 4 Axis Outside and 4 Axis Open
4 Axis Syncing
Dynamic Machining Strategies
Wire EDM Simulation
BobART V33 V34 V35 V36 V37
Rename Sculpting Features
Drag Canvas Size
Automatic Regeneration on Geometry Update
Vectorize and Regenerate Emboss while in Dialog
Emboss: Make as Solid
Upgraded UI and Workflow
Flat End V Tools
V Carve Pocketing
Vectorize Images
Emboss Regular
Emboss Swept
Emboss 2 Rail Sweep
Emboss from Image
Emboss from Surface/Solid
Emboss from BobART Surface
Emboss from Component
Emboss Texture
Mirro/Invert
Sculpting
Smoothing
Save as BobART Surface
Save as Componenet/STL
Nesting V28 V29 V30 V31
Screen Selection
Batch Selection
Holes
Dados
Multi Part Nesting
Part Priority
Part Quantity
Sheet Size
Multiple Sheets Supported
Nest Only
Nest & Toolpath
Cut Direction Control
Machine Order Control
Part Rotation
Distance Between Parts
Stock Margin
Fill Order
Tabs
Part in Part
True Shape Nesting
Export Sheet to DXF
Nesting Job
Nesting Wizard
Layer Sorting Control
Filler Quantity
Angle List
Grain Direction
Advanced Part Parameters
Custom Sheet Shape
Variable Stock Margin
Advaned Sheet Settings
Max Part Distance
Thermal Distance
Cut Large Parts Later
Filler Part Settings
Best Nesting Direction
Nest only full Quantity
Flat End Fit
Nesting Optimizers
Remnant Sheet Settings
PRODUCT FAMILY V33 V34 V35 V36 V37
CAD
Mill Express
Mill 3 Axis Standard
Mill 3 Axis Pro
Mill 3 Axis Premium
Mill 4 Axis Standard
Mill 4 Axis Pro
Mill 5 Axis Standard
Mill 5 Axis Pro
Mill 5 Axis Premium
Wire
Lathe
Mill Turn
BobART
Probing
NC Editor Standard
NC Editor Professional
CAM TREE V33 V34 V35 V36 V37
Multiple Tool Libraries
Show Tool Count in Tool Tree
Chain Picking Manager
Redesigned Tool Crib
Operation Tree
Tool Tree
Updated Tool Assignment
Work Offset Update
Double- Click Edit
Auto Blank Toolpath
CAM Tree Look and Feel
Font for Posting
New Coolant Options
Copy with Geometry
Backplot Tool Visibility
CAM Tree Focus
Post Individual Items
CAM Tree Notes
Hole Recognition
Knowledge Base
Machining Cloud Import
CAM Tree Flyouts
CAM TREE: Tools V33 V34 V35 V36 V37
Tool Crib: Remove Unused Tools
Barrel Mills for 3 Axis Pro: Taper, Double Section, Section
Advanced Rough and Z Level Finishes Utilize Custom Tool Geometry
Tool Tree
Edit Tools in the Tool Crib
Barrel Mills: Standard, Tangent, Lens and more
Machiningcloud Direct Import
XML Import/Export of Tool Library
Flat Bottom V Tools
Tool Library Search Filter
SIMULATION V33 V34 V35 V36 V37
Fixture Collision Detection
Updatable Collision Tolerance
Launch Simulation in Separate Window
Toolpath Analysis: Custom Decimals
Temporary Relative Job Values
Smooth Cutting Quality for X Y Cuts
Retention of Material Display Mode
HOLE MAKING V33 V34 V35 V36 V37
Pecking in Tap Operations
G98/G99 Selection from CAM Wizard
Copy Machine Setups
Operation Tree
Tool Tree
New Mill Thread Leads
Hole Direction Display
Customizable Hole Making Knowledge Base
Hole Feature Recognition - Index System
Hole Feature Recognition - Machine Setup
Pecking Cycles for all Drill Operations
Multi Size Hole Drilling
Multi Depth Drilling
Multiaxis Drill
Cross Drill
Standard Drill
Hole to Hole Sequence Control
Hole Wizard
2 AXIS MILLING V33 V34 V35 V36 V37
Tapered Pockets
Minimize Retracts Enhancement
Copy Machine Setups
Drag and Drop Toolpath Patterns
Spring Passes
Lead from Center
New Leads
Work Offset Update Dialog
Detect Open Edges
Spindle Direction Control
New Pecking Options
New Side Roughing Options
Corner Slowdown
Fixture Selection
Work Offset Pattern
Multiple Step Chamfer
Minimize Tool Retracts
Geometry Selection Manager
4 AXIS MILLING V33 V34 V35 V36 V37
Restrict Links to Clearance Area
Stepover Optimization for Wall Finishing
Floor Finishing
Automatic Tool Contact Point for Turn Mill
Feedrate for Links
Side Shift
3D Containment
Conical Machining
4 Axis Tilt - Advanced Z Level Finish
4 Axis Tilt - Advanced Planar
4 Axis Tilt - Pencil
4 Axis Tilt - Equidistant
4 Axis Port Milling
4 Axis Debrring Operation
Turn Milling Operation
Barrel Mill Supported for Advanced Rotary
Detect Stock Thicker Than for Advanced Rotary
Intermediate Steps for Advanced Rotary
New Advanced Rotary Rough and Finish
MULTIAXIS V33 V34 V35 V36 V37
Custom Start Point
Enhanced Tilting Strategies for SWARF
Automatic Tool Axis Control for Multiaxis Finishing
Fixed Tool Axis for Multiaxis Roughing
Chamfer Tool Support for SWARF
Multiaxs Machining Support for Unconnected Surface Finishing
Multiblade Fillets
Multiaxis Machining Fixture Geometry
Multiaxis Machining Rest Finishing
5 Axis Undercuts for the Advanced Z Level Finish
Auto 3 + 2 Roughing
Multiblade Operation ( Impeller & Blisks)
Port Machining
Multiaxis Machining - Floor & Wall Finishing
Turn Milling
Deburring Operation
Barrell Mill Tool Supported
Automatic Arc – Tool Axis Orientation
Limits Relative to Surface Normal
Multiaxis Roughing – Undercut Machining
Toolpath Smoothing
Feedrate for Direct/Spline Links
Side Tilt By Contact Point
