| Stock Wizard |
    | Rectangular Stock |
    | Cylindrical Stock |
    | Wire Frame Stock |
    | Solid Model Stock |
    | Stl Stock |
    | Job Based CAM Tree |
    | Revolved Stock |
    | Multiple Machine Setups |
    | Toolpath Pattern Array |
    | Toolpath Pattern Translate |
    | Toolpath Pattern Point |
    | Index System |
    | Wrapping Groups |
    | Multi-Threaded 3 Axis Pro Toolpath Calculations |
    | Expand and Collapse CAM Tree Items |
    | Dynamic Machine Strategies in the CAM Wizard |
    | Dynamic Posting Order |
    | Geometry Preview |
    | Operation Preview |
    | Default Parameter Templates |
    | Job Templates |
    | User Defined Machining Strategy Templates |
    | New Machining Order Dialog |
    | Default Machining Order Options |
    | CAM Tree Flyouts |
    | Redesigned Tool Library |
    | Work Offset Pattern |
    | Fixtures |
    | Mill Turn Chuck Jaws |
    | Subprograms for Operations |
    | Keep Bounding Geometry (Stock Wizard) |
    | Simulation Work Offset Pick Point Method |
          | Selection |
            V32 |
    | Open & Close Chain Selection |
    | Color, Layer, Line Style |
    | Pick and Match |
    | Face and Edge Picking |
    | Constant Z Selection |
    | Loop Selection |
          | Toolpath Features |
            V32 |
    | Save/Load Feature |
    | Copy/Paste Feature |
    | Keep Feature Depth |
    | Groups |
    | Locked Features |
    | Update All Geometry |
    | Toolpath Editor |
    | Edit Operation |
    | Apply To All Features/Operations |
    | Groups for Index Systems & Wrapping Groups |
    | Save Feature Defaults |
    | User Defined Strategy Templates |
          | Speed and Feeds |
            V32 |
    | Material/Cutting Conditions |
    | Surface Radius Based Feed Optimization |
    | Tool Contact Based Feed Optimization |
    | Convert Rapids To Feed |
    | Independent Lead In/Out Feed |
    | Adaptive Feed Rate Volume Based |
    | Adaptive Feed Rate Chip Thinning Based |
          | Tools |
            V32 |
    | Tool Library |
    | Tool Types: Tapered Endmill, T-Cutter, Dove Mill, Lollipop |
    | Tool Holder Library |
    | Tool Crib |
    | User Defined Tool Profiles(Form Tools) |
    | Single Window Tool Library |
    | Tool Library Search/Filter |
          | Simulation |
            V32 |
    | Machine Simulation |
    | Setup Sheets |
    | Backplot |
    | Backplot with Detailed Information |
    | Toolpath Statistics |
    | Multi Window View |
    | Measure Grid |
    | Section View/Layering |
    | Click to Advance Toolpath |
    | Zoom Window |
    | Show Previous View |
    | Next Feed Move |
    | Move List Bookmarks |
    | Keyboard Shortcuts for ISO Views |
    | Machine Coordinate System Display |
    | Material Display Mode Retention |
          | CAD |
            V32 |
    | Preview |
    | User Coordinates System(s) |
    | Dimensions |
    | Measure |
    | Text |
    | Text Along a Curve |
    | Show/Hide Axis |
    | Customizable Interface |
    | Standard View |
    | Section View |
    | Dynamic CAD |
    | Snap Grid |
    | Show/Hide Gnomon |
    | New Geometry Picking Interface |
    | Instant Preview |
    | Construction Lines |
    | Dynamic UCS |
    | Layer Attributes |
    | Auto Dimensions |
    | Leader Arrow Note |
    | CAD Tree Optimization |
    | Delete CAD Tree History |
          | Wire Frame |
            V32 |
    | Point Sketch |
    | Point Coordinates |
    | Point Incremental |
    | Point End |
    | Point Intersection |
    | Point Intersection on Extension |
    | Point Arc Center |
    | Point Perpendicular |
    | Point On Entity |
    | Line Sketch |
    | Line Coordinates |
    | Line Join |
    | Line Tangent |
    | Line Parallel |
    | Line Angle |
    | Line Angle Tangent |
    | Line Chamfer |
    | Line Chamfer Single Click |
    | Line Continuous |
    | Arc Sketch |
    | Arc Coordinates |
    | Arc Snap |
    | Arc Fillet |
    | Arc Fillet Chain |
    | Arc Fillet Single Click |
    | Arc 3 Entities |
    | Arc Center 2 End Points |
    | Arc Between 2 Points Diameter |
    | Arc Between 2 Points Radius |
    | Fit Arcs |
    | Rectangle |
    | Rectangle 2 Points(Sketch) |
    | Rectangle 2 Points Center Top |
    | Rectangle 3 Points Length Width |
    | Rectangle 3 Points Half Length Width  |
    | Rectangle Angle |
    | Ellipse |
    | Ellipse with Spline |
    | Spiral |
    | Contour |
    | Offset |
    | Offset Sharp Corner |
    | Continous Sketch |
    | Equalize |
    | Project Curves |
    | Hole Pattern |
    | Point Pattern |
    | Gear |
    | Sprocket |
    | Roller CAM |
    | Shape Library |
    | Shape with Origin Commands |
    | Spline Interpolated |
    | Spline Fit |
    | Spline Blended |
    | Spline Approximated |
    | Spline Multi Geomtery Pick Method |
          | Editing Tools |
            V32 |
    | Mirror |
    | Rotate |
    | Rotate 3D |
    | Translate |
    | Trim Extend |
    | Break |
    | Extract Edges |
    | Extract Edges Project to Z |
    | Stiching |
    | Reorganize |
    | Explode |
    | Reverse Surface Normal |
    | Drag Corner |
    | Deform |
    | Stretch |
    | Nonuniform Scale |
    | 2D Boolean |
    | Spun Profile |
    | Dynamic Scale/Scale Sketch Handle |
    | Unwrap |
    | Unwrap with Chain Selection |
          | Surfaces |
            V32 |
    | Rectangle Plane |
    | Rectangle Angle |
    | Circular Plane |
    | Circular Plane 2 Points Radius |
    | Circular Plane 2 Points Diameter |
    | Circular Plane Center 2 End Points |
    | Circular Plane 3 Points |
    | Planar |
    | Extrude Curve |
    | Extrude Surface |
    | Revolve |
    | Sweep |
    | Cross Section |
    | Skin |
    | Offset |
    | 3 Edge |
    | 4 Edge |
    | Multi-sided Patch |
    | Fillet |
    | Extend |
    | Extend with Face Selection |
    | Intersection Curves |
    | UnTrim Surface |
    | Break Surface |
    | Swung |
    | Ruled |
          | Solids |
            V32 |
    | Sphere |
    | Cube |
    | Cube with Origin Control |
    | Cylinder |
    | Torus |
    | Fillet/Chamfer |
    | Boolean Add/Subtract/Intersect |
    | Extrude Boss |
    | Extrude Cut |
    | Split |
    | Shell |
    | Imprint |
