BobCAD-CAM
What's New in Version 34
SCHEDULE ONE on ONE DEMO
PRODUCT BROCHURE
This release of BobCAD-CAM V34 offers more functionality than ever before. For this release we chose to focus on two major topics: usability and more toolpath power! We have been working very closely with our customers to listen to their everyday programming needs and the minor nuances that would help them get their programs to the machines even faster. From focusing on reducing the amount of times you need to right-click, to more organization in the layer manager, to added tools to manage your work offset numbers, to new toolpaths for deburring your parts, every customer is going to find enhancements in the product that make programming feel more natural.
available Languages
The BobCAD-CAM V34 release is available in the following languages:English, Spanish, French, German, Turkish, Japanese, Czech, Portuguese, and Italian
BobCAD-CAM Version 34 has Many Upgrades and Enhancements affecting the following areas: CAD, CAM, Posting, and General
Solid edge mid-point snap
Here's a handy little extra that available in the new V38: mid-point snap on surface edges! In the past, only the beginning and ends of the surface edge would provide snap points. This was perfect in most cases, but occasionally the mid-point would be needed. Without the snap point, you would need to do a little extra work to extract the edge from the surface and use the center of the resulting line. Now, with the mid-point available its easier than ever to snap geometry right where you need it.
Old snap points
New snap points
New snap points
Join to closest snap point
The Line and Line Continuous functions now offer a check box to control whether the line snaps to the pointer location on the highlighted entity, or whether it snaps to the closest snap point on the entity. Originally these functions automatically snapped to the closest snap point but due to customer requests we updated them to snap to the pointer location instead. Once this was updated though, we had many customer requests to put it back just like it was. So, in this version we're making both sides happy with an easy way to switch between the two options directly in the dialog!
Project Curves: Curves on Curves
The Project Curves function is now capable of projecting separate curves together to create geometry! The project curves function has always been a handy way to create additional geometry by projecting curves, but until now the only thing to project to has been previously created surfaces. In some cases, these surfaces don't exist, which meant you had to take the time to create them prior to projecting the curves. With the new Curves on Curves option, this is all done for you in the background! Simply select the first curves, select the second curves, set the directions, and click OK. BobCAD does all the work for you.
Select first curves
Select second curves
Preview shown
Geometry created
Project Curves: Direction
The Project Curves function now allows you to determine which way the projection occurs with the new Direction option! In the past, the projection always occurred along the Z direction of the active UCS. This made sense, but it meant you sometimes had to update the UCS or even create new ones to get the intended result. Now you can control the direction directly in the Project Curves dialog without needing to adjust your UCS.
Direction: Along Z
Direction: Pick
Diameter text field
BobCAD-CAM V38 now offers a text field for Diameter in many of the CAD functions! In the past, these geometry creation dialogs only offered Radius. This wasn't a big problem since the text fields are also calculators. Though, it did mean that if someone were thinking about the diameter and could only enter radius, they would need to also type "/2" after entering the proper diameter so BobCAD could calculate the proper radius for them. But you asked for it, we heard you, and in this version that diameter text field is there waiting for whenever you might need it!
Layer Manager Updates
The Layer Manager now has a bunch of handy new options to make organization a breeze:
  • Groups
  • Modify to Current Layer
  • Show only this Layer
  • Select Layer Geometry
When we added Group folders to our CAM Tree, customers were ecstatic! Finally, you could use folders, and subfolders to help organize your tree quickly and easily. Now, with our new BobCAD-CAM V38 release we offer those same Groups, and even more to the Layer manager! The Modify to current layer option has been added to the quick access menu of the Layer Manager to quickly move selected items to the active later. You can now right-click on a specific layer to automatically select all geometry at once. And a brand-new feature allows you to right-click a layer and select Show only this layer to automatically hide all other layers.
Solid Chamfer Width
The Solid Chamfer function has been updated to include an option for defining the chamfer by the intended width. In the past the value entered in the Solid Chamfer function has always been Length which, as shown in the image below, is the hypotenuse. Since, in some cases, this is not a known value we have added the Width option to make the chamfer creation even easier!
Chamfer Width
Chamfer Length
Silhouette
The new Silhouette feature allows you to get the overall outline of the part as if it were flattened onto a two-dimensional plane. Getting the outline of a part can be difficult to outright impossible, especially in the case of an STL file. In the past, getting an intersection of curves with an intersecting plane, as seen in the image below, can fail to provide enough to create a proper outline.
Using the Project to Z Plane option in the Extract Edges function is useful, but produces curves for every selected edge, and it can take a while to manually whittle down to the desired geometry.
With the new Silhouette function, just select the geometry, set the direction, adjust options as needed and click OK. All the work is done for you! It even works with STL models!
Selection Manager
The new Selection Manager allows you select any number of entities and save them as a single selectable item so that you can select every one of them with a single click in the future. With each new version, BobCAD-CAM gets easier and easier to use, but no matter how easy, geometry selection can still take time. When many entities need to be selected, zooming, rotating, and panning the model to select the required geometry takes time. With the new Selection Manager though, there's no reason to spend a lot of time selecting the same geometry twice, ever! Simply pick your geometry and save your geometry as a Selection. Next time the same geometry needs to be selected, just give it a quick click in the Selection Manager and it’s all selected at once!
Select all desired entities
Save Selection
Single-click selection from now on!
Extract Isocurve
New to BobCAD-CAM V34 is the ability to extract isocurves from surfaces automatically. Now you can get wireframe geometry curves right from the information stored within the surface data! With the new Extract Isocurve feature, simply select the surface and set values for the U and V directions. You can even use your mouse in the graphics area to select the location for the curves to be created!
Solids / Surfaces
Selected surfaces
Geometry created
This function also gives you the ability to trim the isocurves being created or extend them to the extent of the surface in its untrimmed state. Notice the original size of the surface in the images below. The Trim Isocurves option gives you control over how the curves should be trimmed.
Surface / Wireframe
Trimmed surface
Trim Isocurves
Trim Isocurves
Settings Dialog Updates
User Interface Page: Tree Behavior
The new User Interface page of Settings dialog has a couple things you would already be familiar with, like the Theme and Selection mask options from the User Profile page of the Backstage, but also has the new Tree Behavior options! We wanted to reduce the need to right-click even more by making it so you could simply edit your features, operations and more just by double clicking on the item! We also made this an option, so for any users that preferred the previous method of expanding and collapsing the items can simply set that as the option.
  • Edit - launches the applicable dialog to allow you to adjust parameters in the wizard, edit geometry, set up tools, etc.
  • Expand/Collapse - allows you to expand and collapse items in the CAM Tree.
Note: Tree Behavior applies to items in your CAD Tree, CAM Tree, and BobART Tree.
CAM Page: Auto Blank New Items
The new Auto Blank New Items option allows you to have the toolpath of your new CAM features hidden upon creation! By default, as soon as a feature is created, the toolpath of all operations in the feature is immediately visible. This makes sense, since you're going to want to see if the toolpath appears to be what you had in mind before simulation. However, checking the toolpath of your feature when there are many overlapping operations is nearly impossible. It's easy enough to blank the feature so you can click operations in the CAM Tree to view their toolpath, but with this version we're saving you those extra couple mouse clicks by allowing you to blank newly created features by default!
CAM Page: Look and Feel
This version of BobCAD-CAM gives you the option to save yourself a lot of right-clicking in the CAM Tree, while making it much easier to see the state of each item at a glance! By default, changing the status of CAM Tree items requires right-clicking the item to update the status through the context menu. Once you do, an icon is placed in front of the items name showing that state. This is all pretty standard, but with the new Look and Feel options for the CAM Tree in the Settings menu, you can switch to the new Extended style CAM Tree to save a ton of right-clicks and provide a little visual organization! Now use Blank/Unblank and Post Yes/No with a simple click.
Classic
Extended
We went even further with the new Extended CAM Tree style by allowing you to control the look and feel of it! When we consulted our customer base, it was clear there was a divide where the users would prefer these new options to be, so we just provided you the option to choose yourself. These options let you decide which side of the CAM Tree the states appear, and whether the states are shown as icons or check boxes.
Status Location
Left
Right
Status Style
Icons
Check Boxes
CAM Page: Posting Font
You can now control the font used for your code posted in the Posting Manager. We've been updating the Posting Manager to make several things easier for you, and one thing customers have asked for is the ability to update the font used for the code. While it is strictly a cosmetic enhancement, we heard you, and it has now been implemented.
* Please Font responsibly. If we get a tech support call from your boss because you thought posting in Wingdings would be funny, we're going to take it away
Coolant Options
Previous versions of BobCAD would only allow you to enable a single coolant option per operation which was fine for most of our customers. However, many machines these days have multiple coolant options that can be enabled at once and every manufacturer likes to handle their own and of codes a little differently! Now instead of having to work with the posting department to build you custom posting dialogs in the operations, BobCAD now natively supports up to 10 coolant on and off codes to be optionally used.
Please note that modifications to your existing post processor will be needed to add this new functionality.
Once set, a single coolant option, or a combination of these coolant options, can be turned on by launching the Coolant dialog from operations tool page.
Copy with Geometry
With the new Copy with Geometry option, you can copy all the settings of the feature along with all the geometry associated with the feature and paste it in the same document!
Copying and pasting features can be a huge time saver when programming a part. Making sure all the settings that you’ve taken the time to dial in can help to ease your mind as well, but in the past geometry always had to be selected again. This could be a pain when you have several boundaries, various surfaces selected for gouge checking, other surfaces with advanced allowances applied, and on and on. Now with the new Copy with Geometry option, these troubles are a thing of the past. It’s never been easier!
Backplot Visibility
The new visibility options in Backplot allow you to hide the individual components of the tool! In the past you could control the transparency of the entire tool assembly, but not the individual components. In this release, you can decide which aspects of the tool are visible.
Holder
Arbor
Shaft
Flute
Holder
Arbor
Shaft
Flute
Holder
Arbor
Shaft
Flute
Holder
Arbor
Shaft
Flute
Holder
Arbor
Shaft
Flute
This same functionality is available when backplotting for lathe operations as well!
Holder
Insert
Holder
Insert
Holder
Insert
CAM Wizard Tree state retained
In this version the expanded/collapsed state of the tree inside all your CAM Wizards is retained when the file is saved. When creating a feature with many operations, the items in the tree can easily run off the page and it can be handy to collapse and expand the individual operations. In the past when the wizard was closed and reopened, all operations would once again be expanded. Now, not only is the state of each operation retained when you reopen the wizard, but it's even retained when you save, close, and reopen the entire file!
Post NC Programs for individual items
In this latest version of BobCAD-CAM we're giving you the ability to post particular portions of the program easier than ever before. While you have always been able to control what is posted out by setting everything else to Post No, doing this every time may need to post a different portion of the program can get a little tiring. Now BobCAD-CAM allows you to simply right-click the item and choose Post or Post & Save as to output that portion only! This can be done to output single features or operations, single Machine Setups, a single group, a single Index System, or Wrapping Group. Isolating the portion of the program you want to post has never been easier!
Add Note
The new Add Note option allows you to create your own custom tool tips for items in your CAM Tree! Tool tips can be found everywhere in software and are a great way to get a quick explanation of a functions purpose. Simply hover your mouse over the function and a note pops up. In the new BobCAD-CAM V38 we found a way to help you organize your job even more by giving you a way to create your very own tool tips. Simply right-click the item and choose Add Note. The Add Note dialog appears allowing you to type a message out. Click OK, and a Note icon is added to the item in your CAM Tree. The next time you, or another programmer hovers over that icon, the tool tip appears! Notes can be added to:
Mill Express
Spindle Direction
This new version has updated the user interface to allow the spindle direction to be updated with radio buttons in the tool page. While changing the spindle direction has always been possible be setting a negative Spindle RPM value, we have updated this version to make it intuitive and obvious for new users. With the new Spindle Direction radio buttons, a simple click is all you need to switch between clockwise and counterclockwise spindle directions.
Work Offset Update
Keeping your work offsets straight has never been easier with the new pop-up dialogs! Whether you're updating the work offset of your machine setup, or pasting features between setups, you always want to make sure you'll be posting out the proper work offsets for all your features. When you’re updating the machine setup, this meant having to go through each feature to update it as needed. When pasting a feature into another setup, it meant being sure to remember to update that feature as needed. With the dialogs, this is done for you automatically! When updating the machine setup, the Update Work Offset Number dialog appears allowing you to clear any features you do not want to update. Simply click OK and you're done. When pasting a feature into a machine setup with a different work offset, a dialog appears offering to update the feature automatically!
Updating the Machine Setup Work Offset
Pasting a Feature
Detect Open Edges
The brand new Detect open edge option allows you to control how open edges on selected surface geometry are handled. In the past, features would create toolpath which brought the tool up to the edge without going over whether the geometry had open edges or not. In order to move the tool over open edges, wireframe geometry had to be created and selected to guide the tool over edges. Now, with the new Detect Open Edges option in the Mill 2 Axis Feature Geometry Picking dialog, simply select the check box to get the tool to move over the open edges, or keep it cleared to keep the tool from crossing those edges. Just another option to save you even more time!
Detect Open Edges
Detect Open Edges
Hole Geometry Direction
The direction the hole will be drilled is now displayed in the workspace when using Standard Drill and Cross Drill. While we have shown the direction for Multiaxis Drill holes for some time now, the other methods have not shown direction. In order to add a little consistency between all of the drill hole methods, the direction of the drill hole is now shown in the workspace for all types.
Standard Drill
Cross Drill
Multiaxis Drill
Mill 3 Axis Premium
Deburring
The new Deburring operation allows you to automatically create toolpath to trim complex edges or apply chamfers/fillets to the edges of your parts. For all machined parts, sharp edges must be dealt with. The burrs on sharp edges are a safety issue for the machinists working on them and can even affect the functionality of the part. While taking care of these edges on basic 2-3 axis parts is fairly simple, selecting each individual edge can be time consuming! The new Deburring operation makes this vital step of the machining process a breeze with automatic feature detection, automatic linking, automatic lead in and even automatic collision detection! Simply select your tool, select your geometry, and let us do the rest!
A part with this many edges would normally be a nightmare to deburr, but by just selecting the entire model, BobCAD-CAM V34 gives you all the toolpath you need! The Deburr operation will even do undercuts automatically when a capable tool is selected for the operation!
Mill 4 Axis Pro
Turn Milling
The new Turn Milling operation combines turning with milling tools to power through materials in record time! In many cases turning operations are applied to the stock to remove material as quickly as possible. The only issue with turning material down quickly is when the chips don't break properly and form large piles against the part called bird nests. These can be dangerous to the part finish, tool, and the machinist. The Turn Milling toolpath can be a super-efficient way to remove a lot of material on your 4 or 5 axis milling machines or your Mill Turn machines! By combining the efficiency of turning with the chip slinging power of an endmill, you can have the best of both worlds and power through material quicker than ever without having to worry.
Deburring
The new Deburring operation allows you to automatically create toolpath to trim complex edges or apply chamfers/fillets to the edges of your parts. For all machined parts, sharp edges must be dealt with. The burrs on sharp edges are a safety issue for the machinists working on them and can even affect the functionality of the part. While taking care of these edges on basic 2-3 axis parts is simple, creating a trimming path on complex multiaxis geometries can often take just as long as programming the entire part! The new Deburring operation makes this vital step of the machining process a breeze with automatic feature detection, automatic linking, automatic lead in and even automatic collision detection! Simply select your tool, select your geometry, and let us do the rest!
Mill 5 Axis Standard
3 to 5 Axis Conversion
BobCAD-CAM now allows you to convert your 3 axis toolpaths to 5 axis motion in order to use short, rigid tools in areas that could not be reached with a 3 axis move without gouging. In machining, tool deflection can spell disaster for part precision. One sure-fire way to avoid that is with tools that are as short as possible, but this can be impossible in some areas unless you can tilt into those hard-to-reach spots with multiaxis movements. With 3 to 5 Axis Conversion, you can quickly and easily turn your standard Mill 3 Axis Pro operations into robust 5 axis solutions to keep the precision you need while keeping programming at record low times!
In the image, you can see the arbor is colliding with the model and would not be able to cut that area if a 3 Axis gouge check were used.
By switching to 5 Axis, we can use a gouge check and have it tilt the tool to avoid collisions!
Note: While the 3 to 5 Axis Conversion in Mill 5 Axis Premium allow you to utilize Barrel Tools, these are not available with Mill 5 Axis Standard.
Mill 5 Axis Pro
Multiaxis Finishing
The new multiaxis machining patterns bring the power and speed of the Multiaxis Roughing to finishing! The multiaxis roughing was a revolution in roughing multiaxis parts quickly and easily, but until now a similar solution for finishing did not exist. Generalized toolpath operations have all the settings you could possibly need, so they can be utilized in a wide range of situations. These generalized toolpaths could be applied to the floors and walls of multiaxis parts, but with all those settings they were not designed for ease and simplicity. This meant it could take a bit of toying with all the various options to get the desired result. Now BobCAD-CAM makes it quick and easy to get your floors and walls done with minimal input with these specialized toolpaths:
Multiaxis floor finishing
This path was designed to finish the floors of multiaxis parts. Pick your geometry and let us do the heavy lifting.
Multiaxis wall finishing
This path was designed to finish the walls of multiaxis parts. Pick your geometry and let us do the heavy lifting.
Note: While the Multiaxis finishing operations in Mill 5 Axis Premium allow you to utilize Barrel Tools, these are not available with Mill 5 Axis Pro.
Deburring
Mill 5 Axis Premium
Port Machining
The new Port Machining operation from BobCAD-CAM allows you to machine complex interior geometries with ease and precision. This is a must have for those in the industry! Applying toolpath to curved interior surfaces has always been possible, but it's also been a sure-fire way to test your patience and lose a lose a lot of hair in the process. Spending hours jumping back and forth between tweaking parameters and double checking the simulation to find the necessary combination of settings and values is a thing of the past! This toolpath is specifically designed to handle these geometries with the bare minimum input from the user. Port machining allows you to select the tool, the machining surfaces, and a few check surfaces to get the results you had to struggle so hard for in the past.
Multiblade
The new Multiblade operation allows you to create toolpath on multibladed parts faster than ever before. There's a reason impellers and blisks are used to showcase the multiaxis ability of CAM systems: Multiblade parts can be found everywhere from vacuums to aircraft and have always been the most challenging 5 axis parts to cut. Having to control everything aspect of tool movement on such complex parts requires intimate knowledge of the possible settings and hours of programming. The Multiblade operation has four patterns which are specifically designed to handle a particular aspect of the part. Roughing, Blade finishing, Hub finishing, and Fillet finishing are each designed to create optimum toolpath with very little input from the user. Use the Multiblade operation to flatten the learning curve and turn your hours of programming into minutes!
Auto 3+2 Roughing
BobCAD-CAM now gives the Advanced Rough operation the power to automatically create index systems to tackle your roughing from multiple planes in the same operation. This allows you to use short, rigid tools in areas that could not be reached with a 3 axis move without gouging. In machining, tool deflection can spell disaster for part precision. One sure-fire way to avoid that is with tools that are as short as possible, but this can be impossible in some areas unless you can tilt into those hard-to-reach spots with multiaxis movements. With Auto 3+2 Roughing, you can quickly and easily turn your standard Mill 3 Axis Advanced Rough operation into robust 5 axis solutions to keep the precision you need while keeping programming at record low times! Choose your level of control with:
  • Automatic - allows you to set a search angle increment, a maximum amount of stock to leave, and a maximum tilt range. We'll do the rest.
  • Semi-automatic - allows you to do the same thing, but also allows you to specify a preferred direction of approach.
  • Manual - allows you to take complete control and specify each allowable direction of machining.
Whether you want to pick each of the axis manually as seen below, pick a preferred direction, or just let BobCAD do the work for you, 3+2 Roughing can revolutionize your part programming.
Multiaxis Finishing with Barrel Tools
The new multiaxis machining patterns bring the power and speed of the Multiaxis Roughing to finishing! The multiaxis roughing was a revolution in roughing multiaxis parts quickly and easily, but until now a similar solution for finishing did not exist. Generalized toolpath operations have all the settings you could possibly need so they can be utilized in a wide range of situations. These generalized toolpaths could be applied to the floors and walls of multiaxis parts, but with all those settings they were not designed for ease and simplicity. This meant it could take a bit of toying with all the various options to get the desired result. Now BobCAD-CAM makes it quick and easy to get your floors and walls done with minimal input with these specialized toolpaths:
Search from the Posting Manager
In the new BobCAD-CAM V34, searching your posted code can be done directly in the Posting Manager without the need to launch in an editor! In the past the Posting Manager only allowed you to view the code. In most cases though, if you want to look at the code you want to look for something in the code. This meant that you had to post the code, launch the code into an editor, and then search. If the code isn't the way you want, you would need to close the editor, update the program, repost, relaunch the editor and search again. Now you can simply post, click in the Post Manager, and press Ctrl+F. The search bar appears and you're ready to go.
APT Output
BobCAD-CAM can now output tool position in APT format for Milling jobs. In the past, once your toolpath was ready to send to the machine you would post the code using the default, or custom, post processors in BobCAD-CAM to generate the NC code. In some cases, customer work with a third-party post processing software that handles the creation of the final NC code by imputing the tool position information as a .apt file. Now, you can easily set your NC File Extension to ‘.apt’ in the Current Settings dialog to output in this format.
.NC
.APT
Dwell
A new post question has been added to allow you to remove dwell values of zero when outputting your drilling canned cycles. In the past when the dwell value was left at the default of zero the posted code would output a dwell call with a zero value rather than just leave it out. In this version we've added post question 239 "Output 0 dwell value?". Now, by setting the value of this post question to "n", operations which do not use a dwell will not include that call.
.bbcdx import/export
We have created a brand-new file format to share CAM, BobART and more information between our three separate product lines. The new BBCDX file format allows our users who work with our BobCAD-CAM stand-alone, BobCAM for SOLIWORKS or BobCAM for Rhino product to share information between the systems. While the geometry information will still be different for each system, you will be able to merge in entire CAM Trees, BobART Trees, and BobART models into the other systems to share as much information as can be between these products. For full functionality, the minimum versions of each product required are as follow:
  • BobCAD-CAM V38 SP0
  • BobCAM for SOLIDWORKS V12 SP1
Save As .bbcdx
Open .bbcdx
Top
