Posted April 17, 2018 12:19 pm   Published by    BobCAD-CAM ">
Want to simply and effectively program your 2 and 4 Axis Wire EDM machines? BobCAD-CAM is your powerful, cost-friendly solution with time-saving features that are simple to use. We support the most popular machines with our g-code specific post processors. The amazing new Wire EDM features listed below are sure to be a welcomed addition by any machinist; let’s take a look.
2 & 4 Axis Wirepaths
BobCAD-CAM’s Wire EDM software supports programming for inside, outside and open shapes for 2 & 4 Axis wirepath cutting. Users can program directly off of surface edges on their solids or work directly with wireframe (like a DXF file).
2-4 Axis Wirepath cut in CAM software
Land & Taper
Choose from 3 taper options when programming those 2 Axis profiles: None, taper & land and taper. This makes it easy to setup and program your 2 Axis jobs without needing to create additional operations or geometry. Just pick the geometry and define the taper option needed for the job at hand.
Land & Taper feature in CNC software
Reverse Cut Direction
In all of the Wire EDM machining strategies, the cutting direction of the wirepath for the rough cut, skim cuts and tab cut operations are determined automatically, providing the most effective cutting methods for the application. Users can reverse the cutting direction for any tab or skim cut operations to get control of the cutting direction for all operations.
Reverse cut direction in Wire CAD-CAM software
4 Axis Automatic Synchronization
Having your top and bottom guides line up correctly for 4 Axis cutting is typically the bottleneck for many 4 Axis jobs. BobCAD speeds up this process by providing 3 synchronization options that make 4 Axis programming easier than ever. All options offer a unique method of aligning the top and bottom guide specific to the part geometry you are working with.
4 Axis Sync in CAD-CAM Wire EDM
Toolpath Patterning
Need to create multiple copies of a Toolpath? Using Toolpath patterns, users speed up programming times by “making copies” of a Toolpath in multiple locations. Use an array for a grid style pattern, rotate for a circular pattern or choose a point pattern for irregular locations.
Topolpath Patterning in Wire CNC software
Solid Simulation
“Check it before you wreck it”. Simulation makes visualizing wirepaths easier than ever. Multiple render options make for faster and easier evaluation. Take our new remove chips option, slugs are dropped to provide a more accurate simulation of your machining process.
Solid Simulation in Wire EDM CAM Software
Users can create and import part models, assign wirepath strategies, simulate their work, generate reports and post g-code programs that are specific to their machine with BobCAD powering their shops! Thank you very much for reading another Tech Tuesday, see you next week.
cad-cam software download
Tech Tuesday: Precision Cuts With BobCAD’s Wire EDM CAM Software
Want to simply and effectively program your 2 and 4 Axis Wire EDM machines? BobCAD-CAM is your powerful, cost-friendly solution with time-saving features that are simple to use. We support the most popular machines with our g-code specific post processors. The amazing new Wire EDM features listed below are sure to be a welcomed addition by any machinist!
rssyoutube
