No matter if you are a large, small or medium sized machine shop, CNC software delivers many great advantages to machinists of all skill sets. Many shops have been turning to CNC automation for quite some time to stay lean and turn a profit quicker. Whether it’s adding efficiency to different CNC operations or reducing cycle times by as much as 70%, CAD-CAM software impacts all aspects of manufacturing. Products are made quicker and more affordable than ever thanks to software like that from BobCAD-CAM.
Over the last few years, manufacturing has made a strong rebound in America and it doesn’t seem to be slowing down anytime soon. More often than not, I talk to manufacturers like you that are not only super busy, but they are also even looking into hiring a few more people to aid in the high volume of production. Regardless of what kind of parts your shop produces, here are 5 of the top advantages of using CAD-CAM software to manufacture high-quality parts fast and efficiently.
1. Streamline Your CNC Programming Workflow
One of the best things about CNC software is that it allows users to program parts while machining at the same time. That alone can increase productivity by 50% or greater. Software packages from BobCAD-CAM allow users to import or design geometry for toolpath generation and NC programming that’s quick and intuitive. Material and tooling databases add additional intelligence to programming by optimizing speeds and feeds. Create complex 2D and 3D geometry in a matter of no time by using our smart guides within the software, also known as Machining Wizards. No, these are mythical creatures with a wand. Wizards from BobCAD help users program their jobs systematically, step-by-step with the ability to make edits at a moment’s notice without ruining your job’s progress.
2. Program 2D & 3D Parts Easier
Material and Tooling databases add intelligence to programming toolpaths by optimizing cutting speeds and feed rates. Toolpaths can be created in a short amount of time and can be programmed easily for simple 2D shape-cutting or complex 3D surface machining & contouring. Specialized toolpaths for roughing, finishing and rest machining are efficient, developed for high-speed cutting and proven to reduce cycle times by as much as 70% (via CAM vendor reports). Machining Wizards have been developed to remove the guesswork and provide a smooth transition into CAM programming regardless of program complexity.
Join your fellow machinists. Get the latest Tech Tuesday CAD-CAM articles sent to your inbox. Enter your email below:3. Increase Your Part Making Capabilities
4. Use Simulation To Eliminate Costly Errors & Waste
5. Customize Your Post Processor
Thank you very much for reading another Tech Tuesday. To get articles like these delivered directly to your email, make sure to subscribe using the form above! See you next week!
About BobCAD-CAM
Since 1985, BobCAD-CAM has been dedicated to providing manufacturers just like you with powerful and easy to use CNC programming CAD-CAM software. Our purpose is helping you effectively automate the machining process. We offer CNC programming solutions for Mill, Mill Turn, Lathe, Router, Plasma, Laser, Waterjet, and Wire EDM machines. BobCAD-CAM integrates CAD and CAM functionality in a single interface for a seamless transition from the design process to toolpath programming, simulation, and g-code processing. This design makes it easier for you to go from concept to finished product in less time.
Still trying to get my CNC machine to respond to my G-code.
