In this Topic Show
This topic explains the Parameters available when the Modify Attributes Command Mode, which allows you to modify the feedrate, or feed type, is used. As explained in the Edit Toolpath Dialog topic, most of the Edit Toolpath dialog remains the same, no matter which Command Mode is being used. It is the Parameters of the Modify Attributes Command Mode this topic focuses on, although, the Command Mode group, Selected Toolpath Elements group and the Animation group can still be revisited in this topic by expanding the drop down hot spots of the same name.
To work through an example utilizing this function, see the Edit Toolpath Example - Modify Attributes.
Type -allows you to alter the feedrate of the selected toolpath entities. Choose between:
Rapid - converts the selected toolpath element(s) to a rapid move.
Plunge Feed - assigns the selected toolpath element(s) the plunge feedrate of the operation.
Cutting Feed - assigns the selected toolpath element(s) the cutting feedrate of the operation.
User Defined - allows you to enter a specific value to use as the feedrate for the selected toolpath element(s).
Feedrate - When the User Defined type is selected, this will allow you to enter a specific speed to use for the selected toolpath elements.
Apply to
All - assigns the selected feedrate to all toolpath elements in
the Selected Toolpath Element list, once executed.
