In this Topic Show
This topic explains the Parameters available when the Replace Command Mode, which allows you to draw in your own toolpath and replace entities of the toolpath with this CAD geometry, is used. As explained in the Edit Toolpath Dialog topic, most of the Edit Toolpath dialog remains the same, no matter which Command Mode is being used. It is the Parameters of the Replace Command Mode this topic focuses on, although, the Command Mode group, Selected Toolpath Elements group and the Animation group can still be revisited in this topic by expanding the drop down hot spots of the same name.
To work through an example utilizing this function, see the Edit Toolpath Example - Replace.
Toolpath Chain - lists all entities or edges to replace the Selected Toolpath Elements with.
Pick - enables you to select wireframe entities or edges to add to the Toolpath Chain list.
Link - allows you to set the method of connection between the existing toolpath and the Toolpath Chain that replaces the Selected Toolpath Elements.
Direct Rapid -connects the selected Toolpath Chain with a rapid move.
Direct Feed - connects the selected Toolpath Chain with a feed move.
Direct
Auto - looks at the entities connecting to the entities
being replaced and the replacements themselves to try to determine
the best method of connection to use.
